So after several weeks, I believe the following system is what I'm going to build.  This will be my first build in nearly 15-16 years.  That being the case, I'm I overlooking any compatability issue or any other issue?  I appreciate your help!
Subtotal: $554.98
  Shipping: $1.99
IN STOCK
LIMIT 5
IN STOCK
LIMIT 5
  • $399.99
Subtotal: $2,408.32
  Shipping: $12.07
IN STOCK
  • $69.99
  • $44.99
  • Save: 35.72%
IN STOCK
LIMIT 2
  • $719.99
IN STOCK
IN STOCK
LIMIT 5
  • $139.00
IN STOCK
LIMIT 2
  • $243.99
IN STOCK
LIMIT 5
  • $33.99
IN STOCK
  • $299.99
  • $286.39
  • Save: 4.53%
IN STOCK
LIMIT 5
  • $339.99
IN STOCK
LIMIT 3
  • $499.99
  • $449.99
  • Save: 10.00%
Subtotal: $69.95
IN STOCK
  • $69.95
https://linustechtips.com/topic/781860-final-build-specs-final-input/
This is just my opinion but get a 1440p 144hz monitor over a 4k one. You will have a better overall experience. Also go for a g502 mouse
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
PSU overkill
Mobo overkill
32GB RAM overkill
NVMe SSD overkill
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
Well, You dont have any storage other than the m.2 slot. I'm assuming you have old hard drives you will repurpose?
The PSU and Mobo are extreme overkill. 32 gigs of ram is probably more than you'll ever use
1 minute ago, ZM Fong said:
PSU overkill
Mobo overkill
32GB RAM overkill
NVMe SSD overkill
I just got Ninja'd. Damn my slow typing
Just now, ZM Fong said:
PSU overkill
Mobo overkill
32GB RAM overkill
NVMe SSD overkill
Are you saying I should lower my build specs to save money vs spending more money in an attempt to future proof for a period of years?  I know it's overkill, that isn't the point.
960 pro isnt worth the price
get 2x pm961's and raid them in 0 and get 1.75x speed xD
and the haf stacker is outdated
get the latest mastercase instead
3x 128GB Samsung PM961 M.2 (2x Kryom PCI-E M.2 by Aqua Computer) on windows os raid and 1x PM961 as os Host on the motherboard m.2 slot
+ 250GB Samsung 850 EVO
+ 7200RPM Seagate 1 Terabyte HDD
  • PSU
    seasonic 750 prime platinum Active PFC F3
  • Cooling
    Noctua NH-D15S (original fan replaced by an Noctua 140mm industrialPPC-2000 IP67 PWM + Steel 140mm fan guard)
  • Keyboard
    Cherry MX Board 6.0 ISOANSI + Vector/Tai keycaps+ Landing pads + O-rings
  • Mouse
    BenQ Zowie EC2-A White Edition
  • Sound
    Edirol Roland UA-25EX + Beyerdynamic DT 770 Pro
  • Operating System
    Windows 10 x64 (Enterprise) SP1, OpenSUSE, Remnux
but the evga components are really good picks, especially the z270 board but the sad part is that they removed the I/O cover on the z270 versions..
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
id suggest go have a look on ebay, you are paying full price tho
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
I mean, don't spend on things that doesn't provide any significant benefits for you. Unless you have lots of money to spend.
Also, this is not how you future proof. I would rather spend those money on a better CPU and GPU.
Desktop specs:
What better GPU?  The Titan for like twice the price?  I guess I could change the mobo and CPU and go with a 6 or 8 core processor, spending even more money.  But, for gaming, I think the 7700 is best as it is.
Theres a difference between future proofing and spending money on functionality you dont need or will probably never use.
This argument is best personified by the PSU. Processes and GPU's are becoming more and more efficient. Even SLI can be run off of less wattage.
The board is literally a waste of money. Almost all of those features can be found on boards half the price! I would know because I paid $165 for my Z97 board three years ago. (And are you REALLY going to use the u.2 slot? That form factor was DOA)
You will see very little difference in nvme vs SATA SSD performance.
Okay, MAYBE you manage to use 32gb of ram. Thats a lot of multi tasking though!
TL:DR your money is better spent else ware on other things, not necessarily PC related.
The GPU is basically as good as it gets. Titan XP is not worth the price you pay.
7700K is the absolute best processor for gaming.  (as of today) More cores will not help games in todays time, thoguh with Ryzen launching 6 cores at $250 prices that could soon change.
A 6-8 core Ryzen 7 is cheaper than a 7700K (though you're getting the non K?). But the 7700K is currently the best for pure gaming performance.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Side note, what CPU cooler are you using?
See, I knew I was missing something.  I'll probably add a Corsair H100i v2 water cooled.  Also, in regards to the PSU, if I plan to overclock the CPU to 4.5 or higher, will this type of wattage ever be needed?
I have been debating whether or not I should get a 1440 or 4k monitor.  I'm not sure the graphical differences are that extreme between the two and I know 1440 monitors can be purchased with higher refresh rates.  Are those refresh rates really going to make THAT much of a difference?
That cooler is perfect. No objections there!
You should be able to easily hit 4.8ghz+, and with an OC'd 1080ti, you wont even pass 500 watts. I dont even think you'll hit 400 (though I could be wrong, someone will correct me if I am)
Honestly, yes. High refresh rates are AMAZING!!! Especially in anything fast paced.
A really good psu is the EVGA SUPERNOVA G3, 80+gold rating, fully modular and $95 for the 650w version.
I appreciate your replies, kind sir!
1 minute ago, lee32uk said:
Don't get a Freesync monitor with an Nvidia GPU. Also if you are sticking at 4K resolution I would go for Ryzen over Intel.
I was just looking at this 1440 one because it's the most reasonable with 144:
IN STOCK
LIMIT 2
  • $479.99
IN STOCK
LIMIT 2
  • $479.99
That is also Freesync. You want G-Sync if going with an Nvidia GPU.
