Do people still use fraps?
obs is better.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
9 minutes ago, FirstOfHisName said:
OBS kills my frames. But someone here said that Fraps doesn't take away much frames
FRAPS records in (almost) lossless quality... if there is something to kill your frames it is FRAPS.
Your OBS was not set up properly.
obs is better.
I use both.
36 minutes ago, Spork829 said:
Do you have an Nvidia GPU 700 series or newer? If so, swap to OBS and change the encoder from x264 to NVENC. Has exactly no impact on your framerate.
I use both.
Eh I never really bothered with the settings so u see why, but I just tried recording and fraps was PERFECT 100% playable while recording.
49 minutes ago, deXxterlab97 said:
whats your gpu? you better off using what amd or nvidia has to offer, those stuff are what helps frame rate most
amd has relive and nvidia has shadowplay (now known as share afaik)
Intel HD Graphics so not happening anytime soon.
I use both.
sadly only records for 30 secs. (29) ... As I cannot afford the full version. 37 dollars is a lot in MYR,
If you only record for 30s, how can you say its perfect compared to anything.
Anyway, you might try MSI Afterburner too.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
