Hai! So! I got the Logitech app for my phone, to be able to monitor my CPU, GPU and RAM usage and temp'.
BUT, I've now tested with the ASUS AI Suite III aswell, Logitech app reads atleast 4-5c higher than the ASUS AI Suite III reads, because I've  always monitored the phone when I play to see how much I use of my system.
Which should I trust?!
https://linustechtips.com/topic/781677-logitech-arx-does-not-read-well/
Run some stress test and see if its consistent difference. Like 5C all the time. Then you can trust both, but keep in mind that difference exists.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Yah, I did a stress test with the ASUS Suite III and phone showed a peak at 91c meanwhile the Thermal Radar showed around 83-87~ish!
Maybe its reading from another sensor. Is there some desktop software which needs to be running?
5 minutes ago, WPM-P36✠ said:
For the phone? No, only ASUS Suite which reads from the motherboard itself. As it's the software that came with it.
It seems to be bug of some sort. I did look at some bug reports about Aida64 and Arx with similar issues. You can try and ask Asus support about it, or from Logitech. I have no clue which of them is causing the issue.
I asked about desktop side since I've past tested Roccats software which had desktop client and mobile one.
TBH, I belive more the thermal radar armour than the app as it's wireless and doesn't lay and read the temp as much like the motherboard does! :S Just got me worried when I stresstested and suddenly the meters flashing on the phone. xO !! I mean, I know my CPU cooler is not proppa' attached due to it's not compability with my motherboard :P It's kinda bending and such so.. :C
I saw the other thread. Temps are fine for the cooler. Since its low-profile, it isn't that amazing in performance. Plus, you could try with different orientations.
Tried everything, but the TUF motherboard doesn't seem to have much space for these coolers! D: Not this is not even thread related. :x But I know I will soon get a proper cooler that allows me to fit my second RAM stick aswell :P
