Just finished building
Go to solution Solved by Zando_,
3 minutes ago, dv8t said:
I'm just going purely black and white on this. These were the automatic colours, I'm not a fan of flashy rgb just sticking with white lighting all around.
Nice. I was gonna say to try purple, as I think that'd look good with white. At least you aren't doing green or red (They're overused IMO, but hard to get away from as most affordable "gamin" stuff has to be red and black or green and black)!
Finished my first ever build. I will change all the lighting this is first time boot opening cam software wanted to get a pic! Need to sort out leds also.
7700k
X62
32gb 3200 lpx
960 pro 512
1080ti evga ftw3
I updated the final build picture at the bottom of the thread, ignore this one it was straight after bootup.
i7 7700k OC 5.1ghz
1080ti EVGA FTW3
960 Samsung Pro 512gb
32gb Vengeance LPX 3200mhz
z270 Extreme 4 mobo
x62 AIO.
https://linustechtips.com/topic/781480-just-finished-building/
nicely done, not that much of a fan of the looks but its always nice to finish a build, would like to see more pictures or else its more of a status update thing tbh
Builds:
https://linustechtips.com/topic/781480-just-finished-building/#findComment-9852919
AAAAAAH! GTX 1080 Ti FTW3*! Stop, you're gonna kill me with jealousy! Also, I'm a bit of a Corsair fanboy, but you guys are gonna make me rethink this with all the sweet NZXT fans and AIOs. Sweet build though mate. What RGB colors are you planning on going with?
*Yes, also an EVGA fanboy. And Sapphire for AMD cards.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/781480-just-finished-building/#findComment-9852963
31 minutes ago, NrKj105 said:
*snip*
Well what else do you expect people to use?
S340 Elite or P400 TG are the best cases, and there aren't any mainstream competitors for such a low price point.
HUE+ is by far the best RGB strips
NZXT X42/52/62 is the best looking AIO in most people's opinion.
NZXT gets money and sales for making components that look nice and aren't overly expensive.
Edited by wkdpaul
Cleaned up
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/781480-just-finished-building/#findComment-9852964
thats the point
people just seem to go along with what the maymay techsavvy's tell them to buy because they need unecessary "cable management" or "glass panels"
3x 128GB Samsung PM961 M.2 (2x Kryom PCI-E M.2 by Aqua Computer) on windows os raid and 1x PM961 as os Host on the motherboard m.2 slot
+ 250GB Samsung 850 EVO
+ 7200RPM Seagate 1 Terabyte HDD
  • PSU
    seasonic 750 prime platinum Active PFC F3
  • Cooling
    Noctua NH-D15S (original fan replaced by an Noctua 140mm industrialPPC-2000 IP67 PWM + Steel 140mm fan guard)
  • Keyboard
    Cherry MX Board 6.0 ISOANSI + Vector/Tai keycaps+ Landing pads + O-rings
  • Mouse
    BenQ Zowie EC2-A White Edition
  • Sound
    Edirol Roland UA-25EX + Beyerdynamic DT 770 Pro
  • Operating System
    Windows 10 x64 (Enterprise) SP1, OpenSUSE, Remnux
https://linustechtips.com/topic/781480-just-finished-building/#findComment-9852972
1 minute ago, NrKj105 said:
thats the point
Glass sidepanels look good, and usually people like JayzTwoCents recommend quality products.
I'm not advocating the same cookie-cutter systems everywhere, but using mainstream parts makes sense for most people, and cable management is something everyone should do. taking pride in your system and wanting to show it off is normal. you want it to look good.
Laptop:
https://linustechtips.com/topic/781480-just-finished-building/#findComment-9852991
i7 7700k OC 5.1ghz
1080ti EVGA FTW3
z270 Extreme 4 mobo
x62 AIO.
https://linustechtips.com/topic/781480-just-finished-building/#findComment-9852993
Mouse: EVGA X17
https://linustechtips.com/topic/781480-just-finished-building/#findComment-9853026
Purple looks really good. Cheers dude
i7 7700k OC 5.1ghz
1080ti EVGA FTW3
z270 Extreme 4 mobo
x62 AIO.
https://linustechtips.com/topic/781480-just-finished-building/#findComment-9853092
