$2.000 Gaming rig help ?
I went on an adventure for you my friend from Europe.
I searched komplett.dk and cinemagic.dk for the best and cheapest components
which would also satisfy most of your wishes.
I'm glad you learn English up there in Scandinavia, because your languages are garbage
- I cut down on your graphics card, wel.. not really!
- And you will have to make love to another case. The Stryker will most likely leave you, because it's a pricey bitch.
- I found a PSU which is almost the same as the AX760 but cheaper.
Reasons behind the slight changes:
---Graphics card
EVGA sells one of the best looking graphic cards in my and also in your opinion.
But they are quit expensive compared to other manufacturers like ASUS.
So I swapped the EVGA GTX 780 with an Asus GTX 780 DirectCU II. You will save about 400DKK.
The Asus card also matches perfectly with your MoBo. (you could also use the red fan rings and go for a black/red/white theme)
---Case
The Coolermaster CM Storm Stryker costs about 1150DKK.
You get some really nice features.. which you will never use.. I promise you.
I also recommend you a more slick look to a computer case, because you will never
regret buying a gimmicky case, which you wont like in a few years.
The Define R4 gives you everything you want. A sidepanel window, good airflow, and super quiet operation.
You could also look into the Arc Midi R2 by Fractal Design. It has similar features, but isnt as quiet as the Define R2.
But there are so many different options for cases. But I recommend staying within a 800DKK budget for it.
---PSU
Well the PSU was pretty easy.. The Corsair RM650 is pretty much the same as the AX760.
You will give up on the 80 Plus Platinum certification, but 80 Plus Gold is as good as it gets in this budget.
You won't have a fitting red label on the PSU, which you won't see if you close the case anyways.
650 Watts will be perfectly fine for this build plus overclocking.
So here you go. I checked overclockers, but the slight savings you would've gotten there would be useless due to
shipping costs to denmark (fucking islands).
All in all I could get a total of 11460DKK, which is slightly under the 2100$ mark.
I would recommend you to find out if you can get a Windows Key for less than 800DKK.
You have some saving potential there.
I hope I could help you with that. Enjoy building your new system.
Hilsen fra Tyskland!
