ROUTER AS A SWITCH WITHOUT NETWORK PING ISSUES
Solved by brwainer,
Just now, DBG said:can u suggest any other switch and will it even reduce the ping?
Buy any Gigabit switch. In theory it will reduce the ping, but I do not guarantee it, and it won't reduce it by much (less than a 2ms difference). And the same thing about making sure the computers use the wired connection, and not wireless, still would affect you. But if you bought a gigabit switch, you would not want your ports set to "100 full Duplex", you would want them set to Auto or to Gigabit. Also the gigabit switch will only help if your computers have gigabit ethernet ports.
