Hey guys , I recently bought a new computer and i have already asked here in this forum about this topic but I have some new findings and figured I'd just make another post.
So my specs are :
Core i7 7700K
Asus ROG STRIX 1070 GTX
MSI Z270 M3 Motherboard
16GB Hyper X Savage CL12
Corsair H100i V2
5 Magnetic Levitation fans (3x 120mm , 2x 140mm)
Corsair 400C Carbide
500GB Samsung 850 EVO SSD
RM750x 80+ Gold
I have installed my motherboard's drivers as far as i know
I have installed my GPU's drivers
And i installed a couple of other stuff but that's mostly utility software like MSI afterburner
I set a fan curve that seemed logical to me
I am using HWmonitor to monitor my GPU and CPU temperatures as i play games or whatever and the problem is :
As soon as i start up a game like League of Legends , Rainbow Six Siege or Cs:go , my CPU's Temperature would go up dramatically , from my 40C idle (It's a bit high cause it's hot where i live) To maybe 60-65C in a few moments just for being inside the Rainbow Six Siege Main Menu. Then , after i close the game , it would shut down the window and do some processor stuff to sync things with Uplay when i quit a game , which can sometimes make the temperature rise up even more up to 70C.. I have no idea what the issue is.. I wish I knew and i wish i could get some help with solving it.. should i try to reapply the water pump of the H100i or is there no way it would make such a big difference? what's wrong then..
PS :
If you guys have some really good Stress tests that should give me a certain result and statistics of other people with similar components then i could get a picture of whether my pc is performing well or not and i'd appreciate it a lot.
https://linustechtips.com/topic/780953-help-with-temperatures/
its an issue with Intel processors
see vid
https://linustechtips.com/topic/780953-help-with-temperatures/#findComment-9845917
70C isn't a big deal...
Stress with RealBench.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/780953-help-with-temperatures/#findComment-9845935
2 minutes ago, Sierra Fox said:
70 is fine
I know 70C isn't a big deal guy's but for barely any load (just the task of quitting a game) takes it up to 70C and then the odd thing is it dips down after it's done working right back into the 40's in a matter of just one second.. how can it even do that
https://linustechtips.com/topic/780953-help-with-temperatures/#findComment-9845958
Guest
