I have an old 1156 mobo from an AiO system which i'm upgrading for LAN parties and wanted to make a PC from the old components and give it to my aunt which really needs a newer one (still has an old P4)
Problem is, it has an odd USB issue, after a while of usage it starts popping up ''USB device not recognised'' and any USB device disconnects and reconnects, tho sometimes it doesn't reconnect at all until i leave the PC off a bit to cool down. The southbridge gets really hot and cooling it with a fan makes the problem disappear from what i see.
I already replaced the thermal paste. Is it dying or is there something else giving issues? (leaking capacitor or such?)
https://linustechtips.com/topic/780212-motherboard-usb-issues/
If the south bridge is getting too hot and cooling it makes the issue go away then I think the case needs more airflow.
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9836992
maybe your burning out your southbridge, and when it gets too hot the computer disconnects power to that USB port and has to cool down
Feel free to quote me if you want an answer
NAS hard drive list feel free to PM me questions or anything about Hard drive as i am in love with them
I fly the Boeing 737-800 for Turkish Airlines
"Men, this stuff that some sources sling around about America wanting out of this war, not wanting to fight, is a crock of bullshit. Americans love to fight, traditionally" - George.S Patton
"There are four hundred neatly marked graves somewhere in Sicily. All because one man went to sleep on the job. But they are German graves, because we caught the bastard asleep before they did." - George.S Patton
"An Army is a team. It lives, sleeps, eats, and fights as a team. This individual heroic stuff is pure horse shit. The bilious bastards who write that kind of stuff for the Saturday Evening Post don't know any more about real fighting under fire than they know about fucking!" - George.S Patton
"Sure, we all want to go home. We want to get this war over with. But you can't win a war lying down. The quickest way to get it over with is to get the bastards who started it. We want to get the hell over there and clean the goddamn thing up, and then get at those purple-pissing Japs. The quicker they are whipped, the quicker we go home. The shortest way home is through Berlin and Tokyo. So keep moving. And when we get to Berlin, I am personally going to shoot that paper-hanging son-of-a-bitch Hitler." - George.S Patton
 Specs
Home Rig:        :
CPU: Intel I7 3770 @ 3.4 Ghz
CPU Cooler: Hyper 212 Evo
GPU: MSI Radeon Rx 550 Aero ITX 1gb (amazing gpu btw)
RAM: 2x4 Mismatched Ram Sticks
Motherboard: Pegatron 2AD5
HDD: 1TB WD BLUE
Case: HP 7500 Series MT Case
PSUCooler Master 500W Elite
Workstation:
CPU: i7 5960x @4.3Ghz
CPU Cooler: Kraken X62
GPU: Gigabyte GTX 1080 Ti 1G
RAM: Kingston HyperX 32GB DDR4 2133Mhz
Mobo: Asus X99- Deluxe
HDD: WD Blue 4TB 5200RPM
SSD: Samsung 850 EVO 500GB
Case: Corsair 750D
PSU: Corsair RM 750x
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9837004
problem being that this was in an open case and it's the first time seeing this issue in general, especially this bad, i've had densely packed PCs before with almost no airflow and the southbridge never go this hot.
How? I only have a M&KB connected to the USBs. When the M&KB stop working, then all of the USBs don't connect at all, it's like everything is just dead until i restart the PC. Even cooling the SB after it gets hot doesn't help, USBs aren't coming back until i restart the PC
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9837047
i probably think its burning out because i had the same problem a while ago on my work pc, until one time when i was using it smoke started pouring out and the computer shut off, so better get it checked out
 Specs
Home Rig:        :
HDD: 1TB WD BLUE
Workstation:
Case: Corsair 750D
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9837061
Is it a particularly old computer? Some of the first things to die on old machines are the USB ports.
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9837062
Haven't had smoke yet, tho smoke probably means a capacitor died and blew, most likely, so it could be a faulty capacitor leaking too much power to it.
It's an old 1156 board from an AiO PC (PackardBell) and from what i see Lenovo is the maker of the mobo. I know USBs like to die, but the thing here is that they work until the SB overheats and then they stop, if it's cool they work even under stress.
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9837076
Well, that puppy got fried and had to replace the motherboard, i hope i helped you and best of luck
 Specs
Home Rig:        :
HDD: 1TB WD BLUE
Workstation:
Case: Corsair 750D
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9837126
Unpredictable issues can arise with computers when they get old. If you can tell cooling the south bridge make a difference in how the USB ports respond then you've solved your own issue. You said the south bridge never use to get this hot. Well as I mentioned earlier these things can just pop up out of nowhere. Plus as computer hardware ages it can lose its efficiency (power in/performance out) they can inexplicably run hotter and consume more power. This is a sign the south bridge could be failing. For now more sufficient cooling seems like it solves the problem but a real fix would be a new motherboard.
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9837437
nono, i bought this AiO to upgrade it and use for LAN parties, when it was in the AiO the USBs worked, or atleast as much as i used it before disassembling it to put in the new components. I meant after having hundreds of motherboards this is the 1st time i had an issue with overheating SB, that's what i meant by that.
Yeah, new mobo is better, but like i said i thought of giving my aunt the system since she has an  old P4 PC still, i could always get one of those SB heatsinks that is bigger and has a fan on it. Or just DIY one on there.
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9837460
Alright.
You can buy relatively cheap copper heatsinks. How you'll attach it I don't know but it should help keep the temperature down.
https://linustechtips.com/topic/780212-motherboard-usb-issues/#findComment-9839179
