Motherboard help
Go to solution Solved by Spuriae,
This image is large enough for you to read the markings on all the caps if you zoom in:
So i got this good deal on this motherboard https://www.asus.com/us/Motherboards/Z170-P-D3/ for about 20$.
But there is one small problem. One of the capacitors is missing. It is the one betwen the cpu and ram slots.
Can someone help me identifi it ? I dont want to put just any capacitors there.
https://linustechtips.com/topic/780175-motherboard-help/
Just now, George_Bud said:
Why ?
The capacitor it's off and it might blow up something
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/780175-motherboard-help/#findComment-9836467
1 minute ago, George_Bud said:
I intend to solder a new one.
Ok test with hardware you don't care if it dies
https://linustechtips.com/topic/780175-motherboard-help/#findComment-9836492
  Hide contents
So 560uF 4v capacitor.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/780175-motherboard-help/#findComment-9836593
