So The glass in front of the camera on my nexus 6p broke, and I havent gotten around to buying a new glass and changing it yet.
Now the glass shards in front of the camera fell out, so the lens on the camera itself is exposed. Is that dangerous for it? should tape over it or something to protect it until I can change it (shoudnt be that hard)?
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
https://linustechtips.com/topic/780008-camera-exposed-nexus-6p/
Personally I would use a blower to blow out any dust in there already then cover it with clear tape.
Getting that piece of glass as a replacement part will probably be pretty hard though......  Maybe it's the first time I have every said this, but maybe you should get it fixed somewhere.
https://linustechtips.com/topic/780008-camera-exposed-nexus-6p/#findComment-9834383
Oh, anyone know where I can buy the glass?
Like anyone know a trusted good seller on ebay that sell them, and preferably can ship to Europe without being not to expensive?
-Stephen Hawking
https://linustechtips.com/topic/780008-camera-exposed-nexus-6p/#findComment-9834602
