Whats this for?
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832805
Just now, Xatris said:
This is for a PC I am building mainly used for video production.
What system specs?
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832815
You need more than a 200 watt PSU, that's for sure.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832838
I would recommend 600W as the absolute minimum.
What kind of budget are you looking at? You have a high end CPU, but a rather budget GPU so I'm assuming you are on a bit of a budget.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832851
I have a 1050 Ti in my current build (before I build my new one.) You need at least 130 watts (I believe) to run the card. Say the processor is 90 watts and everything else is about 150. You should invest in at least 500 watts. Also, I can say that the 1050 Ti is NOT for video production, but it more of a 1080p budget gaming graphics card. You might want a 1070 or 1080, in which you would need somewhere around 600-700 watts.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832864
Ummm What ? You dont need anywhere near that. For SLI configs you can use a 600w for any single card 500 is the most, the biggest area the cards have improved is efficiency.
@Op Get a better quality 450-500w and you'll be go to go for all upgrades.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832890
I said for a 1070 or 1080. If he had two 1050 Tis he would need at least 260 watts for the gpus alone. A 1080 is what, 300 watts each? In SLI, he would need something like an 800 watt. Whatever.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832895
My budget for the build is about $1000 to $1500 (American)
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832898
I did the master cooler wattage meter thingy and his is what it gave me.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832901
1080 is 500w on a full system, so please tell me what exactly is the point of a 700w for his build ?
@Xatris check the MSI power calculator and the PCpartspicker one, those are very reliable.
Redstone:
Obsidian:
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832909
1050Ti's don't SLI.
I don't want to plunge this into a thread where we evaluate your build choices, but it might be worth taking a look at Ryzen since you get more for your money. It would allow you to allocate a bit more of your budget to PSU.
I would recommend something like a SeaSonic M12II power supply, I believe they are all fully modular, are very reliable and might come with a fan-less mode (their fans are practically silent anyway).
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832913
I didn't say they did, I simply gave an example. I know they don't, for crying out loud I have one.
I just saw you mention two 1050ti's, I'm not really reading many other posts besides the OPs.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832928
Those are not always reliable and only give you an estimate at best. I typically look at the power rating that the manufacturer lists for their part, add 15-25% then add the powers together. I also make sure that I'm not exceeding more than 80% of the power supplies maximum output power.
Try taking a look at this list here.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9832970
For a X99 + GTX 1050Ti setup, 200W is a bit low. With that being said, grab a Corsair CX450M and you should be fine.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9833010
For one, if using Adobe Premiere there's hardly any video card acceleration from CUDA. Just having an Nvidia GPU will work, could be a GTX Titan or 750 Ti. Will work about the same.
Second, 600-700W is what would be recommended for two of each of those GPUs in SLI with a 6800K.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9833096
you 2 are high if you think 500w and 600w is needed for a gtx 1050ti, high-end cpu or not.
http://www.legitreviews.com/msi-geforce-gtx-1050-ti-4gb-geforce-gtx-1050-2gb-video-card-review_187298/14 221w peak gaming load with a 1050ti and 4960x.
@boltoflightning 600w is absolutely not needed for a gtx 1070.
http://www.legitreviews.com/nvidia-geforce-gtx-1070-founders-edition-video-card-review_181760/14 281w peak gaming load with a 4960x and gtx 1070, 321w with a gtx 1080.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9833197
hahaha thats what I've been saying ! !
Redstone:
Obsidian:
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9833211
So, I allowed the power output to go down to 400W, and the 520W units are still the cheapest.
https://linustechtips.com/topic/779884-i-nee-a-power-supply/#findComment-9833319
