Aura 140mm fans dont exist?
RedShift7
Evening
As the title suggests at im looking for an Asus Aura ready RGB 140mm fan...but they don't seem to exist.
Cooler Master do a nice looking one but it is only 120mm. Has anyone seen a 140 anywhere else? Seems odd to have a 120 but no 140 variant
Thanks
3 minutes ago, RedShift7 said:
Evening
Thanks
Currently there are no 140mm RGB options that can be synced up with Aura, the only RGB sync capbale fans being the Coolermaster Pro and Akasa Vegas x7 both being 120mm.
and the NZXT AER fans
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
They're specific to the NZXT Hue + controller since they work on an addressable RGB system which won't work with the Aura or other motherboard control systems.
ah ok
Corsair released last month a 140mm version of their HD series ;)    but like the Aer from NZXT, they require a controller. You can buy a dual pack with controller version, but the controller is really limited. The best is to get a lighting node pro too, which gives you the ability to control via Corsair Link.
