Power Supply.
Go to solution Solved by STRMfrmXMN,
1 hour ago, Jack03 said:
https://pcpartpicker.com/product/3pqdnQ/xfx-power-supply-p1550gts3x
Is this power supply enough for a Ryzen 5 1600 and a GTX 1070 both overclocked or do I need more wattage?
550W is about double what that system will draw. That PSU should be fine.
plenty.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/778022-power-supply/#findComment-9812646
its going to be fine, id get a 650W but thats still going to be fine even for overclocking
Builds:
https://linustechtips.com/topic/778022-power-supply/#findComment-9812651
For $2 more you can get an EVGA g2 from amazon which has modular cables. https://pcpartpicker.com/product/qYTrxr/evga-power-supply-220g20550y1
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/778022-power-supply/#findComment-9812701
https://linustechtips.com/topic/778022-power-supply/#findComment-9813124
