My CPU is Seriously overheating!
Ok, let's take things one at a time.
For processors, they should not run at more than 65-70 degrees Celsius, most processors will throttle themselves down (reduce maximum frequency) if the temperature goes above that threshold.
For video cards, they're designed to run at higher temperatures and they're more efficient (consume less power when they're warmer). Most will idle at 50-60 degrees Celsius and by design will keep the fans spinning at lower speeds to keep the cards silent and cold enough to stay in the sweet spot.
When gaming, it's perfectly fine for modern video cards to stay all the time at temperatures up to 80-85 degrees Celsius, most video cards will adjust the fan speeds to keep the cards under this temperature.
Some older video cards (like Radeon 4850 or 4870 or 48xx in general) were designed for even higher temperatures, it was normal for those cards to reach 90-95 degrees Celsius and stay there.
Thermal pastes are meant to fill empty spaces, microscopic holes in the surface of the cooler heatsink and the lid on the processor, they're meant to be applied as a thin layer and no in excessive amount. For the same reason, it's best to apply the paste as a pea size ball in the center of the processor because when you put the heatsink down on top of the processor, the pea will be flattened and will spread in all directions at same time, and there won't be any air trapped between the metal surfaces and the paste.
If you spread the paste before and then put the heatsink over, there will be "valleys" in the thermal paste layer and when you put the heatsink over the paste the paste peaks will act like glue and the air in the valleys of the thermal paste may be trapped there and decrease the efficiency of the thermal paste.
Now as you already found out, thermal pastes only change the temperature by a few degrees. Between no paste and some paste (any kind of paste) there may be around 3-5 degrees Celsius of temperature, but between any paste and a better paste like MX-4, there may be only 2-3 degrees Celsius difference.
The stock cooler should keep your cpu below 60c when it's used to the maximum, so if your temperature is often more than that, it's unlikely to be the thermal paste.
My first guess would be that maybe there's not enough pressure between the heatsink and the processor.. maybe you're not mounting the cooler correctly, or maybe the clips are weakened or the plastic is bad on those pins Intel usually uses for stock coolers?
If the clips or whatever is used to keep the heatsink down on the processor are somehow weak or faulty, you'll probably have to replace the cooler, but with that processor you really don't need to use a 50$ cooler, especially if you're in a country where such amount is a lot of money.
You also shouldn't need more than a couple of extra fans to have some airflow through the computer case, to move the warm air around and towards the top of the case where it goes out.
