RAID 0 problem
Go to solution Solved by MekaMain,
I'ts working now, thanks
RTFM
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/77607-raid-0-problem/#findComment-1065014
I think the intel rst is only bios not uefi so if you have raid enabled check to see that your booting storage with both not uefi. Also if you are in uefi look around and makesure there isnt a new tab or page somplace for raid options.
https://linustechtips.com/topic/77607-raid-0-problem/#findComment-1065092
