As the title says, my Razer Naga Hex V2 randomly stops tracking while in game. All the buttons on it work, it just stops tracking. Usually before it quits, it jerks the mouse up or down.
An example of this would be, I was playing CSGO and I noticed my mouse started to jerk down and up. It eventually gave out after 2-5 jerks down/up, and in the situation I was in, my character was looking at the ground from all the jerking. I couldn't move my mouse up, and eventually I ran right into the enemy, and he killed me.
My question is, how can this be fixed? I've tried multiple USB ports on my computer, and all seem to have the same effect.
Should I use compressed air to clean the sensor, or should I contact Razer Support/use my warranty to get a new one?
https://linustechtips.com/topic/775997-razer-mouse-stops-tracking-randomly/
Just now, RickNickHD said:
-SNIP-
Try a different a different surface or running the surface calibration that should ensure it is properly tracking, if it still continues you may want to contact them for an RMA.
Check to make sure that your mouse is being handed off to the main program correctly. You can usually test for this by playing a game until the issue occurs and then Alt + Tab'ing out and back in. If it continues, I'd try another PC. If it occurs still, bad sensor and you can try to clean it.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
