Hello My name is Jonathan and I am building a new Budget Gaming pc for myself. I need to know if these parts will work together. Any help is very much appreciated Thanks!
1.Case: Xion Performance ATX case/ 2.PSU: EVGA 500 Watt 80+ Bronze/ 3.MotherBoard: MSI Socket AM3+/AMD 760GMA-P34 (FX) DDR3 mATX/ 4.Processor: AMD FX 8300 Black Edition/ 5.GPU: RX 460 Windforce OC 2GB GDDR5/ 6.RAM: (x1) 8gb stick 1866MHz DDR3/ 7.CPU Cooler: Hyper 212 Evo/ Storage:1TB Caviar Blue HDD.
https://linustechtips.com/topic/775967-compatibility-help/
I agree, highly recommend Ryzen. I dislike all other AMD processors but Ryzen is looking great!
Edit: Didn't refresh and didnt see your reply
  • CPU = i7 5930k
  • Cooler = Corsair H100i
  • RAM = Dominator Platinum 32GB DDR4-2666
  • Storage = Samsung 850 Pro 1TB
  • GPU = EVGA GTX 1080ti FTW3
  • PSU = Corsair 750D
  • PSU = Corsair 1000W
  • Monitor = Asus PG278Q
https://linustechtips.com/topic/775967-compatibility-help/#findComment-9788385
@jonny.lizotte If you can get a Ryzen 5 CPU for a similar price, it would definitely be a good idea. It is always worth getting the latest CPU architecture and motherboard chipset for future compatibility. AM3 didn't have support for windows 10 in a lot of cases, and AM3+ may not have support for future versions of windows; it is an antiquated platform.
There are pros and cons to Intel vs. AMD, but at the moment it seems Ryzen 5 CPUs are definitely the best balanced CPU choice in that price category. A corresponding B350 chipset and 8gb DDR4 RAM should work out at roughly the same price, and provide much better performance, as well as compatibility for future generations.
That said, FX CPUs still offer great price:performance - you can get them very cheap. So if you simply cannot make the step up to Ryzen you will get away with one for what you are trying to do, but just don't expect it to last you too long.
https://linustechtips.com/topic/775967-compatibility-help/#findComment-9788459
Just now, jonny.lizotte said:
I need a cheap GPU for around 100$ to go with my ryzen 5 1400 CPU. Any Ideas?
RX 470? 570? 1050 TI?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/775967-compatibility-help/#findComment-9788878
1 minute ago, jonny.lizotte said:
I don't think that will work on this board:Gigabyte GA-AB350M-HD3 AM4 AMD B350 2 Way CrossFire
No, it has a PCIE slot so it will work.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/775967-compatibility-help/#findComment-9788884
Ok but on amazon the RX 470 is like 200$.
https://pcpartpicker.com/product/tyNypg/gigabyte-radeon-rx-570-4gb-gaming-4g-video-card-gv-rx570gaming-4gd
Or if thats too expensive:
https://pcpartpicker.com/product/wrmxFT/evga-geforce-gtx-1050-ti-4gb-acx-20-video-card-04g-p4-6251-kr
But the RX 570 is a lot better.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/775967-compatibility-help/#findComment-9788891
