Soundblaster Recon (PCIE) or onboard sound (Strix Z270E)
Solved by theklax,
At that price point (the speakers), I should think it'll be impossible to notice a difference in audio fidelity.
With that said, separate (from the mobo) audio sources can be useful if your mobo has poor shielding and your speakers are picking up electrostatic noise. This isn't normally a problem with very modern mobo's because they've come leaps and bounds (even in the last few years) in terms of shielding tech.
As the previous posts have said, test it using the onboard first, and add the sound card if necessary.
