I'm confused. It's been mining for 10 min but it doesn't show any signs on the website that it's been mining and says 0.0000000000000000 BTC
*mildly autistic*
CPU: Intel Core i7-5820K @ 4.2 GHz | Motherboard: x99 RampageRAM: 16GB DDR4 GPU: Nvidia 980 Ti SSD: Looking for one |
https://linustechtips.com/topic/774766-am-i-doing-it-right/
2 minutes ago, Mooshi said:
You're doing the equivalent of trying to do construction with a plastic spoon...
So...?
*mildly autistic*
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9773901
Just now, TheRandomness said:
Because you're running such weak hardware, that'll take (probably) a few years to mine a reasonable amount of btc (maybe.. 2-5 of them?).
Oh ok. ?
*mildly autistic*
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9773903
Check website: whattomine and you can see what is the most profitable to mine right now with your GPU.
GPU mining is profitable only for those who have cheap or free electricity and use at least 50 GPUs. Otherwise you will be making like 0,5€ profit per day .... not worth the strugle.
I can go out for 1 hour, and I'm sure I will find 0,5€ on the floor somewhere much faster than you earn it by GPU mining with single low tier card.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9773925
Oooh that harsh.. I like it.
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9773967
33 minutes ago, LionWaffles said:
snip
Step 1: Rent a huge warehouse
Step 2: Buy like 30-50 racks of Servers.
Step 3: Buy like 100-200 AMD RX 580s or Fury Xs
Step 4: Insert the GPUs into the server racks.
Step 5: Profit?? :D.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9774004
Harsh or not, it's how it is.
I did some mining with my GTX 1070 and I earned like 30$ in 1 month ... It did feel good to get 30$ just like that. But next month when I received bill for electricity .... well it was exactly 25$ more than usuall.
10/10 would't recommend.
And that was with mining Zcash which was the most profitable at that time.
WD My Cloud 4TB
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9774007
Shiee, I don't know anything about this but that's nooo profit.
Buy a coffee at a café and you're done.
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9774011
Exactly ... mining with your daily PC is not worth it anymore.
But if you have something like this + free electricity, then go for it since you are looking at few hundred dolars per day. But keep in mind that you also have to invest in all that hardware in the first place. And usually electricity isn't for free xD
WD My Cloud 4TB
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9774026
Man all that hardware looks juicy :D
https://linustechtips.com/topic/774766-am-i-doing-it-right/#findComment-9774048
