Budget? Any goals for the PC? Anything you want specifically? More details, or we can't help you.
Better dead than Red.
Pheonix
CPU: i5 2500k @ 4.6ghz Mobo: Asrock Z77 Extreme4 RAM: G.Skill 16gb of DDR3 @ 1600mhz GPU: Gigabyte GeForce GTX 1060 6gb Extreme Gaming PSU: EVGA 700B Storage: 480GB SP SSD and a 960GB Ultra II Sandisk. Cooler: Cryorig H7 Case: Phanteks P400.
https://linustechtips.com/topic/774402-plz-help/#findComment-9769412
Just now, MVPernula said:
As cheap as possible with high framerates in CSGO, not really a huge deal to do that.
Do you need 200-300FPS?
Are you gaming on a 120Hz or above monitor?
i need a high fps and i don't have a monitor this is my first build. Thats why i said include a monitor that fits with it.
https://linustechtips.com/topic/774402-plz-help/#findComment-9769428
Alright.
Do you have an actual budget? It helps.
If not we can just try anyways to make it as cheap as possible.
https://linustechtips.com/topic/774402-plz-help/#findComment-9769442
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($217.55 @ OutletPC)
Motherboard: ASRock Fatal1ty AB350 Gaming K4 ATX AM4 Motherboard  ($102.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($70.92 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.66 @ OutletPC)
Video Card: Gigabyte Radeon RX 570 4GB Gaming 4G  Video Card  ($168.99 @ SuperBiiz)
Case: Xion XON-350_BK ATX Mid Tower Case  ($22.98 @ Newegg)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Monitor: Acer GN246HL 24.0" 1920x1080 144Hz Monitor  ($182.99 @ Best Buy)
Total: $864.07
Generated by PCPartPicker 2017-05-02 08:40 EDT-0400
The more cores you throw at CS the more framerate. GPU doesn't matter.
Hammers 1-3 cores hard and 4-6 not so much
Runs well on Ryzen, check 2klipsphillip's video on it
idk
https://linustechtips.com/topic/774402-plz-help/#findComment-9769479
Total: $864.07
thanks.
https://linustechtips.com/topic/774402-plz-help/#findComment-9769484
PCPartPicker part list: https://pcpartpicker.com/list/p9sRbj
Price breakdown by merchant: https://pcpartpicker.com/list/p9sRbj/by_merchant/
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($59.48 @ OutletPC)
Motherboard: Gigabyte GA-Z270P-D3 ATX LGA1151 Motherboard  ($96.98 @ Newegg)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  ($54.77 @ OutletPC)
Video Card: EVGA GeForce GTX 1050 Ti 4GB SSC GAMING ACX 3.0 Video Card  ($147.95 @ Amazon)
Case: BitFenix Nova ATX Mid Tower Case  ($26.99 @ NCIX US)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.88 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($86.88 @ OutletPC)
Monitor: Asus VG248QE 24.0" 1920x1080 144Hz Monitor  ($229.99 @ Best Buy)
Keyboard: Corsair Vengeance K65 Compact Mechanical Gaming Keyboard Wired Gaming Keyboard  ($59.99 @ Amazon)
Mouse: Corsair M65 PRO RGB FPS (White) Wired Optical Mouse  ($49.99 @ Corsair)
Total: $920.56
Generated by PCPartPicker 2017-05-02 08:46 EDT-0400
https://linustechtips.com/topic/774402-plz-help/#findComment-9769496
Total: $920.56
there other one was cheaper
https://linustechtips.com/topic/774402-plz-help/#findComment-9769501
6 minutes ago, Westy55 said:
Ok, lets say my budget is 700 what's the best i could get..
https://pcpartpicker.com/list/Rhn3kT
i tried to shave some off. This pc is only about 600$ without the monitor and mouse. It's kinds important to have a nice mouse and monitor for cs
https://linustechtips.com/topic/774402-plz-help/#findComment-9769572
8 minutes ago, Westy55 said:
do u have a pc i could buy
Depends on what you have in your local used market really...
But I can give recommendations on old hardware.
AMD HD 7770 is the cheap and cheerful option, but only pulls 100fps @ 1080p ultra settings. If you want around 144fps, you will need a 7970.
On Nvidia's side, a GTX 570 can pull 144fps @ 1080p ultra. The cheaper (and newer) alternative is the GTX 750t, with 110fps @1080p ultra.
CPU: Even old core 2 quads can go quite far, but to quad cores, I'd say i5 xxx or newer. Dual cores, i3 2100 or newer.
Desktop benching:
https://linustechtips.com/topic/774402-plz-help/#findComment-9769573
Thread cleaned.
This thread is about build suggestion, not about CS:GO frame rates and input lag, feel free to make a topic about that but this isn't this thread's main topic.
Also, it was moved to the New Builds& Planning section.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/774402-plz-help/#findComment-9769652
Just a friendly reminder that the "response time" advertised on monitors are meaningless because they do not actually measure what consumers think they measure. There is also no industry standard for how to measure it so what one manufacturer might say is 3ms response time, another might say is 1ms response time.
For example the MG238Q from Asus, which is one of the fastest monitors on the market, had a total display latency of about 4ms, even though it claims 1ms.
The Swift PG348Q is sitting at around 9 ms latency.
Your eyes and brain for example, takes about 15 milliseconds to process an image. So even that slow Swift monitor is way faster than your brain and eyes. Of course, cutting down on the individual parts in the "latency chain" is important because they all add up in the end, but it's not at all as important as some people think.
A lot of it is just circlejerking about how awesome people think they are because they think they can notice the difference between 3ms.
So look up reviews on for example TFTCentral if you are super worried about response time of monitors.
https://linustechtips.com/topic/774402-plz-help/#findComment-9769685
