Hello folks, I seem to have a problem "could be normal" When I turn on my Witcher 3 game on ultra setting and play for a bit that temprature on my GPU stays on 84c. Is that normal? keep in mind that my GPU is founder edition EVGA so i didn't expect great cooling. My case fan setting is set to positive. 3 120 fans for intake and 1 140 fan for outtake from the back.
https://linustechtips.com/topic/772641-1080ti-fe-heating-issues/
84C is acceptable for a blower style cooler. It's also why you shouldn't choose this over other cards when you have so many case fans for heat dissipation.
Desktop benching:
https://linustechtips.com/topic/772641-1080ti-fe-heating-issues/#findComment-9750043
I think 84°C is causing it to throttle, so your performance will be a bit lower than it could be.
As long as you keep your GPU under 85°C it will be just fine.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/772641-1080ti-fe-heating-issues/#findComment-9750053
3 minutes ago, MVPernula said:
I think you can change the fan speed for the cooler.
If I'm not mistaken it only hits 100% when up on 90c, so maybe dowload MSI Afterburner and change the fan curve?
Might help! :D
+1 turn the fan up...it might get loud, but it might be preferrable to lowering the settings.
It's why I don't use blowers...too loud for me...I generally only use open coolers and distribute the cooling burden across multiple quiet case fans running at regulated speeds (currently got a closed loop on my 970 because I had it laying around but...generally speaking I have an open cooler graphics card and utilise multiple, quiet system-fans to manage the heat).
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/772641-1080ti-fe-heating-issues/#findComment-9750099
seems normal, as the FE edition cards have pretty crappy coolers. as stated above, turning up the fan helps with cooling, but also leaves you with a jet engine in your case.
if you really want silence but don't want to skip on performance you could look into the hybrid solutions available, like the Kraken G10 bracket with a small AIO.
https://linustechtips.com/topic/772641-1080ti-fe-heating-issues/#findComment-9750118
