hi, i have a evga supernova 650w g1 fully mod, and i wanted a either a full psu cable kit with the cables as white as possible, or a few crucial cables that you would be able to see clearly through the side panel. my case is an nzxt s340 elite in white, and my gpu is a galax 1080 exoc snpr, which has an 8 and a 6 pin. I dont want to get a kit thats like 80-90 bucks, cause i think thats way to expensive for cables, but i definitely need the cable that would show, like gpu, 24 pin, cpu 8 pin, to be white. i would prefer a full cable kit just for a clean look all around, but if its way to expensive then nevermind. thank you!!
https://linustechtips.com/topic/772528-need-help-with-psu-cables/
Take a look on Cablemod's website I bet they would have something similar
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
@FerbTheOG you can find your PSU under our selection of PSU's on the configurator page here:
https://store.cablemod.com/configurator/
