I'm looking to create my first PC build. I'm pretty new to this but I have some friends that helped me compile this list and I did some research on my own as well. This is what I have so far.
PCPartPicker part list: https://pcpartpicker.com/list/zXbff8
Price breakdown by merchant: https://pcpartpicker.com/list/zXbff8/by_merchant/
CPU: AMD Ryzen 5 1600X 3.6GHz 6-Core Processor  ($248.49 @ OutletPC)
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler  ($115.00)
Motherboard: Asus PRIME X370-PRO ATX AM4 Motherboard  ($155.49 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($101.99 @ Newegg)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($83.85 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($359.99 @ Newegg)
Case: Thermaltake Commander G42 ATX Mid Tower Case  ($60.99 @ SuperBiiz)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Total: $1230.68
Generated by PCPartPicker 2017-04-27 16:34 EDT-0400
This computer will mainly be used for gaming and some CAD work.  I want the main color to be black and I may end up adding RGB lighting in later.
Possible Changes:
CPU Cooler-I might ditch the liquid cooling for an air cooler that I can get at a cheaper price. I do plan on overclocking but I don't know if the performance increase from the liquid cooler will be worth the extra cost.
Motherboard-I'm considering switching out the x370 motherboard for a B350 motherboard because it should allow me to save a bit of money and I'm not sure if I need all the capabilities of the x370 motherboard.
Memory-I'll probably end up switching out these for different memory that's black but I don't think it will have much of an impact so I just left it for now.
Video Card- I was initially set on the 1070 but then I heard that the new AMD cards will be coming out before the end of May. I would be willing to wait for these if they could offer better performance for the price. If I do go with the 1070 though I don't know which manufacturer I'm going to use cause I don't really know what the difference is or why there are so many different types of 1070s.
Case- I would prefer something with a side window, preferably tempered glass, and even though I don't need an optical drive right now it would be nice to be able to add one in the future.. The case I have right now is just something I threw to finish the build. If I do end up going with the liquid cooler the case has to have a slot for at least a 240mm radiator.
Power Supply-PCPartPicker says this build should use around 370 watts so I chose a 500W power supply to make sure I have enough power and to leave room for possible upgrades. I am a little concerned about the quality of this power supply because it was so inexpensive.
Any tips are appreciated. I might be wiling to raise the price a bit if it were to offer a significant performance increase but this is pretty close to my max price and I'm actually looking to lower the cost of the build as I still need to buy peripherals. For a monitor I'm looking for a 1440p with a decent refresh rate so if you have any tips for how I can get one of those for a decent price that would be helpful. I'm willing to buy a used or refurbished monitor if I could get it for a good price and in decent condition. I'm probably going to be using a second monitor as well but I don't have it yet and it doesn't need to be that good of a monitor.
https://linustechtips.com/topic/772458-first-build-advice/
Get the 1600 instead, it's just as good. The PSU is pretty mediocre.
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($217.55 @ OutletPC)
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler  ($46.88 @ OutletPC)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive  ($56.95 @ Amazon)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($379.99 @ Amazon)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Total: $1153.68
Generated by PCPartPicker 2017-04-27 17:12 EDT-0400
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/772458-first-build-advice/#findComment-9747840
CPU Cooler: NZXT Kraken X52 Liquid CPU Cooler  ($144.33 @ OutletPC)
Motherboard: MSI B350 TOMAHAWK ATX AM4 Motherboard  ($108.29 @ OutletPC)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($114.99 @ Newegg)
Case: NZXT S340 Elite (Black) ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.89 @ OutletPC)
Total: $1273.77
Generated by PCPartPicker 2017-04-27 17:37 EDT-0400
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/772458-first-build-advice/#findComment-9747972
The PSU is pretty mediocre, this would be much better:
https://pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na
I've heard a lot of people suggest switching out the 1600x for the 1600. Why is this? Is the extra clock speed on the 1600x not worth it?
https://linustechtips.com/topic/772458-first-build-advice/#findComment-9747992
Both will overclock to about the same level anyway, so there's no point.
PSU Tier List | CoC
https://linustechtips.com/topic/772458-first-build-advice/#findComment-9747998
abit over but:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($313.99 @ SuperBiiz)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  ($27.98 @ NCIX US)
Motherboard: MSI Z170A SLI ATX LGA1151 Motherboard  ($82.98 @ Newegg)
Memory: Patriot Viper Elite 16GB (2 x 8GB) DDR4-2666 Memory  ($97.99 @ Amazon)
Storage: Western Digital Blue 250GB 2.5" Solid State Drive  ($83.98 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.49 @ OutletPC) get later if you can't handle rebates.
Video Card: MSI GeForce GTX 1080 8GB DUKE OC Video Card  ($484.98 @ Newegg)
Case: Azza Photios250 ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: Corsair CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($63.98 @ Newegg)  take note; grey unit, not the green one.
Total: $1266.36
Generated by PCPartPicker 2017-04-27 21:27 EDT-0400
https://linustechtips.com/topic/772458-first-build-advice/#findComment-9748825
Thanks for the feedback everyone. I think I'm going to end up switching to a B350 Motherboard, I'll have to do some research on that to see which one I want, and get an air cooler instead of the liquid cooler as long as it can support overclocking for the 1600. The intel i7-6700k build was interesting especially since it included a GTX 1080, but I don't think I'll be able to afford a monitor that can actually make use of the 1080s capabilities right now so I'm probably going to stick with the 1070 unless AMD's new GPUs turn out to be good. I've also considered going down to a 1060 or a RX 580, but I'm not sure if the price difference will make up for the drop in performance. I'll probably try to put together an intel build though just to see what I can get but from a glance it looks like it will be hard to match the performance of the AMD CPUs at the same price point. For the Intel build I'm not sure yet if I should use a i5-7600k, the i7-6700k, or the i7-7700k.
https://linustechtips.com/topic/772458-first-build-advice/#findComment-9749557
