Choose the ones you like best
9 members have voted
  1. 1. IO configuration/position (multiple choice if you cant decide between two or three)
    • A
      3
    • B
    • C
      3
    • D
      3
    • E
    • F
Choose which IO config you think looks best and is more convenient (to press the power button)
PS-
difference between D and E is the length of the small ventilation slot
difference between E and F is alignment of the power button, either centered (E) or aligned to top (F)
https://linustechtips.com/topic/772034-custom-pc-case-io-decision/
It is a tad strange to me to have the power button on the back but if it is then A or C would likely be the most convenient but I chose D because it looks cleaner and the spacing feels nicer which is enough to out weigh the convenience of A or C
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
What's the difference between A&C?
Overall I like those because the power button is on the outer side for easier access.  It's be nicer if the clip for the ethernet jack faced away from the power button, so you don't accidentally bump it, but depending on what you're doing, you might not have a say in how that is oriented.
I'd say A or C, primarily A because it gives more room above the power plug.  More context as far as case construction/orientation MIGHT change my answer though
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
The spacing, A doesn't cut into a vent slot
The Impossibox
WhisperingKnickers
x58 Fan Page
C actually gives you an extra half slot
The power button is there so that all 5 sides of the PC are blank, and it will only need to be pressed like once or twice a year ;)
Thanks for the input.
In C the power plug is shifted left and an extra short slot is added.
You're right about the clip, I will do that :)
The back is the only interesting side of the case. All other 5 sides are blank ;)
I chose D, but my only nitpick would be the Ethernet jack being turned around in case the power button is hit.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I deal a lot with case engineering, myself.  Even if it's an infrequent use, when I build it I still want it to be convenient and comfortable in use.  Sad thing is, when I'm done...........I'm not done.  I tend to be a perfectionist on some of the menial details.
I'm actually considering moving the power button inside the case now, it will be used extremely rarely since the PC will be up 24/7.
Pretty much the only time I would need to use it is when installing windows or after a power outage.
Wake on lan is also an option, but a physical button inside is always good.
Unfortunately no MITX motherboards have an onboard power button :C correct me if I'm wrong...
That should allow that half-slot to become a full slot and make the back even cleaner.
Circles don't really fit in with rectangles very well anyway :P
Ideally, for the most minimalism, there would be no ethernet port, only power (and it would use wifi).
But since this computer will be running servers I need it to have the reliability of a wired connection.
Thanks for voting everyone :) Will probably go with D but without the power button.
