Need help, please. No POST ryzen
Go to solution Solved by AkhTwo,
2 hours ago, AkhTwo said:
Guys. I tried connecting my laptop to monitor through male to male HDMI wire. But I couldn't get the display on the monitor. So is this due to a bad HDMI cable?
The HDMI port is not working on the new monitor. The monitor has posted after I started using the VGA.
Guys. I need your help. Please. I assembled my PC last night. Every connection has been given except usb 3.0  front panel header. But I don't know why the system is not posting. Is it because I might have broken the pins on the CPU while adjusting the stock cooler multiple times while screwing it. Also, I double checked that every connection has been given. I tried with single ram stick at all locations, but no use. Please help me
https://linustechtips.com/topic/771742-need-help-please-no-post-ryzen/
The pins on your CPU are fine. I can't see how you could possibly damage them from mounting the cooler. Don't worry. Could you give some more details on whats all going on? A list of components would also be helpful.
Desktop - CPU: Ryzen 7 3700x | COOLER: be quiet! Dark Rock 3 | MOBO: ASRock X370 Killer SLI/ac | RAM: 32GB Corsair Vengeance LPX 3200MHz | GPU: MSI RTX 2070 Super Gaming X Trio | STORAGE: 2x XPG SX8200 Pro 1TB, Crucial MX300 525gb, Seagate Barracuda Pro 4TB | CASE: Phanteks P400s TG White | PSU: Corsair HX750i
Laptop - Dell XPS 13 | Intel i7 7500u | Intel HD 620 Graphics | 8GB RAM | 256GB M.2 SSD
Peripherals - KEYBOARD: KBD67 Lite w/Gateron Milky Yellow Pros | MOUSE: Razer Deathadder V2 | AUDIO: Sennheiser HD 6XX, Truthear Hexa | MONITOR: Dual 1440p 27" MSI Optix MAG274QRF-QD
I didn't know that one has to push the screws hard down to align it with the mounting bracket. So I kept on remounting it again and again in different positions. While remounting I had trouble because the thermal paste got stuck between the CPU and the wraith spire cooler and I have used some force to separate them. So I thought I might have broken the pins.
My parts
Gigabyte GA AB350 gaming 3
Ryzen 5 1600
Wraith spire cooler
Kingston hyperx predator 3200 mhz 2*8 gb
Seasonic S12 II 620W PSU
WD Green 240 GB SSD
BENQ VZ2350HM 23 inch monitor
Gainward GTX 1070
BTW the RAM is listed in the QVL of the MOBO site
