audio system help
Solved by spwath,
9 minutes ago, Ahoy Hoy said:http://www.maplin.co.uk/p/maplin-mini-tos-to-digital-optical-adapter-a61xf
One of them in the back of the play station, then theres a big long cable on the sub, that goes into that. Then the smaller speakrs plug into the sub, plug the power plugs in, change any settings on the ps3 to send audio through digital output and your done.
no, that won't work at all.
that's for digital, won't work.
just get a rca to 3.5mm female adapter, plug into ps3, and plug into green cable from speakers
