Hello!
I searched a little bit and decided i need some help from you guys. So. The problem is i just bought the NZXT s340 PC case and my PSU's cables are too short!? I wanted to upgrade to a 80+ AND modular PSU for a while now and i think that now is the time. I'm looking for a modular 600w 80+ bronze/gold etc... modular PSU In a range about 50-100€ and available in Slovenia or Europe. Any help would be appreciated.
Specs:
CPU: Intel Core i5-2400 + stock cooler
GPU: Radeon R9 290 - Watercooled
Ram: 2x4gb
MOBO: MSI H61M-P31/W8
PSU: LC Power 600w
Case: NZXT S340
Storage: 250gb SSD + 250gb HDD
Watercooling: EK-XTOP SPC-60 PWM, 2x120mm fans
https://linustechtips.com/topic/770868-nzxt-s340-psu-help/
I bought an EVGA 650 G2 Supernova for my S340 Elite (same case size-wise) and the cable lengths appear to be just right. Cost me $90 US on Amazon. 80+ Gold and fully modular.
Current Build:
CPU: Ryzen 7 5800X3D
GPU: RTX 3080 Ti FE
RAM: 32GB G.Skill Trident Z CL16 3200 MHz
Mobo: Asus Tuf X570 Plus Wifi
CPU Cooler: NZXT Kraken X53
PSU: EVGA G6 Supernova 850
Case: NZXT S340 Elite
Current Laptop:
Model: Asus ROG Zephyrus G14
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
CPU: Intel i7 8700K @4.9 GHz/1.315v
Mobo: Asus Prime Z370-A
https://linustechtips.com/topic/770868-nzxt-s340-psu-help/#findComment-9729240
1 minute ago, Emberstone said:
I bought an EVGA 650 G2 Supernova and the cable lengths appear to be just right. Cost me $90 US on Amazon. 80+ Gold and fully modular.
Excellent build quality too.
Pick any from tier 1-3
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/770868-nzxt-s340-psu-help/#findComment-9729242
I've been interested in those for a while now but now, that I've seen some bad reviews about the CXM series im not really into that anymore.. Anyone know anything about the FSP PSU's ? found this partially modular one and it doesnt look like garbage BUT it is not 80plus certified. Would it run fine?
https://edigital.si/napajalniki/fsp-600w-12cm-hyper-m-600-napajalnik-p452608
https://linustechtips.com/topic/770868-nzxt-s340-psu-help/#findComment-9729444
The CXM is going to have bad Newegg and Amazon reviews like anything else. A CX550M would work totally fine for your system. If you could spend a wee bit more an EVGA 750B2 should do you nicely though.
https://linustechtips.com/topic/770868-nzxt-s340-psu-help/#findComment-9730858
