So this is the build I'm planning on doing. The cooler is just a place holder. https://pcpartpicker.com/list/qW9qgL
But i want to add a water cooler on it. The diypc site says it supports 240 and a 280 mm water cooling. But, I cant add it on the site because the site says it doesn't support a water cooler. Im thinking on getting a corsair hydo 560 or a 580i v2. Will those water coolers work on it?
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/770787-does-this-case-support-water-cooling/
What's some cheaper ram, I don't want 8 GB. An s340 only has 1 fan, so that won't support water cooling and it has less stuff. @nerdslayer1
2 minutes ago, nerdslayer1 said:
get a
-7700k
- cheaper ram
-cheaper mobo
- an SSD, you don't need m2.
a s340
My Rig
 Peripherals
@nerdslayer1 But the diypc d480 is cheaper, has more fans, has both an in and out sound port, and a fan controller, why not get that. Also whats some cheaper ram.
My Rig
 Peripherals
2 minutes ago, Vandorlot said:
@nerdslayer1 But the diypc d480 is cheaper, has more coolers, has both an in and out sound port, and a fan controller, why not get that. Also whats some cheaper ram.
https://pcpartpicker.com/list/3gfFr7
Some 16GB kit that isn't $120. A little harder with RAM getting tremendously expensive recently.
The S340 has two fans. I own one. The fans are great. Both are preinstalled at the rear of the case.
There's a ton of room at the front with a radiator placed there too.
4 minutes ago, NSDUO said:
If u wanna overclock
A 7600K could be OC'd to 1.3V with something like a Cryorig H7 easily.
No worries with the s340.  The case is well known for liquid cooling setups.  If you're ever in doubt check the actual manufacturer's website for these sort of things.
Yeah, tower heatsinks like the evo or h7 generally do the job just fine for modest overclocks.  Liquid cooling is obviously cooler looking and gets the best temperatures, but if you want value get one of those instead.
