So I heard that ryzen just like "Single Rank And B-Die Memory" in order to get its full performance,
and also that the best spot is "3200 MHz". Is this information really true?
If yes which RAM should I buy. Forget to mention that it is a theme build so if the RAM is red I
would appreciate that.
https://linustechtips.com/topic/770248-best-ryzen-ram-help/
well, ryzen likes faster speed ram, not necessarily because of the ram, but because of some internal parts that run at ram speeds.
that said, your best bet will be ram that is advertised to run at those speeds on ryzen, because if it doesnt you can expect support.
https://linustechtips.com/topic/770248-best-ryzen-ram-help/#findComment-9722829
Generally the G.Skill Flare X and Fortis seem to be working best (Not the TridentZ though, that is more Intel focused RAM). They seem to be having the best time hitting the highest clock speeds.
Also, I would suggest you check out this site to see some user experience with your particular motherboard: http://rymem.vraith.com/
https://linustechtips.com/topic/770248-best-ryzen-ram-help/#findComment-9722868
10 minutes ago, jonbush1234 said:
vengeance is a really good over all ram i use it in my intel rig but i helped a friend build a ryzen rig and i works like a charm
The RAM you linked is CL16, indicating that it's not using Samsung B-die, which is optimal for Ryzen.
The cheapest kit guaranteed to have Samsung b die AFAIK (not sure if the 2133 and 2400 MHz fortis and flare x kits have b die) is this:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232225&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Memory+(Desktop+Memory)-_-N82E16820232225&gclid=CjwKEAjw_uvHBRDUkumF0tLFp3cSJACAIHMYBuoUYLIeNVkA_OqU_kbVTtbD5y6i2ywAiRgIr_Sd7hoCldXw_wcB&gclsrc=aw.ds
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/770248-best-ryzen-ram-help/#findComment-9722875
@Kilo One I'd recommend getting this kit, as it's guaranteed to be single rank b die and goes with your color scheme well.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/770248-best-ryzen-ram-help/#findComment-9722879
I have a 16 kit of Trdient Z RGB on my Ryzen build, havent had any issues besides the LEDs stopped working on one stick for awhile. Little bit of software tuning cleared that up though
Fanboys are the worst thing to happen to the tech community World. Chief among them are Apple fanboys.
https://linustechtips.com/topic/770248-best-ryzen-ram-help/#findComment-9722923
I got this set https://www.newegg.ca/Product/Product.aspx?Item=N82E16820313777 its was on sale for $10 less
With Ryzen 1600 on an Asus Prime B350-Plus with Bios 5015 it is running at 2933mhz using DOCP. Otherwise is runs at 2666mhx. Check the qvl for your motherboard. It will list what ram they tested and what stable speeds they achieved.
If the kit you buy is on the qvl you know it will work and at what the minimum you can expect. In my case I expected 2666mhz and I got it. After the bios upgrade I got a stable 2933mhz. Its not 3200mhz but the value is their
https://linustechtips.com/topic/770248-best-ryzen-ram-help/#findComment-9723014
I would be G.Skill flare X. More people getting 3200MHz than any other ram brand. I couldn't get corsair vengeance to even 2600MHz. I believe they have red.
https://linustechtips.com/topic/770248-best-ryzen-ram-help/#findComment-9723649
