Hi guys I need help in building my pc
My Rig:
Msi B150m Vdh pro
Zotac Gtx 1060 AMP edition
WD 1 tb hard disk
Hyper X Fury 8x2 gb ddr4
Amd ryzen 1600 3.2 ghz
This is my Rig So I know that I didn't mentioned about my PSU,because I am still thinking which one should I buy so I want to know from u guys that which psu should I buy and if I should do any changes in it my budget is 750$or800$ and I want to play games like Battlefield 1,uncharted 4,CSGO,fifa so can they run with my current Rig at 1080p or medium settings and what will be its fps
https://linustechtips.com/topic/770072-pc-build-help-pls/
B150 isn't compatible with ryzen, you need a B350 motherboard. Try using pcpartpicker.com to list your parts, as it lets you post a link to the organized parts of your rig and lets you know if there are any compatibility issues :)
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720801
Just now, Majestic_Koala said:
If you want to save some money then the EVGA500W B2 is good for the price
If not then i would say the EVGASuperNova G2 550W
What? There is no 500W B2, only 750W.
OP, the Seasonic S12II 520W, Corsair CXM 450W/550W, etc would work perfect for that.
idk
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720805
Ah my apologies, meant the 500W B
Seen herehttps://uk.pcpartpicker.com/product/zNK7YJ/evga-power-supply-100b10500kr
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720811
Other than that it's a solid rig and you could run games like battlefield 1 and uncharted at very high to ultra with 60fps+.
The EVGA supernova G2 units are really good, you could also consider something like a Corsair RM550x or CX550m (silver label, the green label ones aren't that great.)
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720814
How good is the EVGA 430w Bronze for budget builds?
http://www.evga.com/Products/Product.aspx?pn=100-W1-0430-KR
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720816
Ah, still not a fan of the B series. Based on a cheap HEC design. HEC don't make particularly good quality low end stuff.
idk
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720829
Firebomb-tier. Same parts as the 430W White, but with better ripple control.
idk
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720841
1 minute ago, Kratos123 said:
Should I change my processor from amd ryzen 5 1600 to Intel i5 6600 3.3 ghz
More like you should change your motherboard the r5 1600 is a better processor than the i5 6600
Personal Desktop":
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720868
Is VS 550 good for this build
no. get the s12ii instead.
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720874
w1 430w is mostly good for office builds and low-end HTPCs tbh, the only GPU i'd trust with it is a gtx 1050. they're not as bad as what driodbot claims.
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720895
I made a very very budget limited build using it, rocking an old GTX 560ti and Intel Core2Duo e7600, it seems decent enough but yes if you're going new and slightly better I suppose shouldn't be taken into count.
Personal Desktop":
https://linustechtips.com/topic/770072-pc-build-help-pls/#findComment-9720911
