R5 1400 has a bad value
CPU cooler choosen sucks. Get air coolers instead (or stock cooler)
Don't get NVMe SSD
PSU overkill
Case fans a bit overkilll
8 minutes ago, Dodgeyou said:
a cheap PC tailored for silence
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
Don't get NVMe SSD
PSU overkill
Well by cheap I meant under $800, I should have said that, what would you recommend as a PSU for the build and I went with the Ryzen 5 1400 because it will last longer for what they need then one of intel's cheap 2 core CPUS and the fans were just because they are really nice an quiet and I like to use them for builds whenever i can
if you're parents are just doing nothing other than simple web browsing a 1400 is overkill. a G4560 would be more than enough for years. do you have anything other than the gpu you can reuse?
All I really have around for a system is an old FX-4300 and some DDR3 ram but I really wound't want to give them an old FX chip especially such a weak one at that
18 minutes ago, Dodgeyou said:
So i'm building a new PC for my parents as their aging Gateway has trouble browsing the web anymore and I wanted to build them a cheap PC tailored for silence, what are your thoughts?
https://pcpartpicker.com/user/Dodgeyou/saved/RNPdCJ
You're parents don't need a 4 core 8 thread computer, they ain't playing call of duty on it, get a g4560.
lttstore.com
For daily browsing that's all they need.
lttstore.com
a simple web browsing rig doesn't need anything much, even a potato is good enough. reuse it and just add in an ssd, it will keep up just fine.
PSU - any unit with semi-fanless fan/low RPM profile fan/hydro bearing fan like EVGA G2/G3 and Bitfenix Whisper M
Ryzen 5 1400 not the best value. The G4560 is a cheap 2 core CPU but IT HAS 4 THREADS which makes it the best budget CPU right now.
Why you want to get case fans if you want full silence? Fans definitely will make noise no matter how quiet they are. Why not just don't get them?
Desktop specs:
reuse your other components, trust me when i say it's enough.
Motherboard: Asus M5A78L-M PLUS/USB3 Micro ATX AM3+ Motherboard  ($46.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($80.49 @ SuperBiiz)
Case: Rosewill SRM-01 MicroATX Mini Tower Case  ($19.99 @ Amazon)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($29.90 @ Newegg)
Total: $177.37
Generated by PCPartPicker 2017-04-20 23:57 EDT-0400
if you need a cooler:
https://pcpartpicker.com/product/hJFPxr/deepcool-cpu-cooler-gammaxx400
Mooooaaar silent
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($59.48 @ OutletPC)
CPU Cooler: be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($63.99 @ SuperBiiz)
Motherboard: ASRock B250M-HDV Micro ATX LGA1151 Motherboard  ($62.99 @ SuperBiiz)
Memory: Patriot 8GB (2 x 4GB) DDR4-2133 Memory  ($50.00 @ Amazon)
Storage: ADATA SU800  128GB M.2-2280 Solid State Drive  ($48.98 @ NCIX US)
Case: Zalman ZM-T1 PLUS MicroATX Mini Tower Case  ($28.99 @ SuperBiiz)
Power Supply: SeaSonic X Series Fanless 460W 80+ Platinum Certified Fully-Modular Fanless ATX Power Supply  ($109.99 @ B&H)
Total: $424.42
Generated by PCPartPicker 2017-04-20 23:59 EDT-0400
1 minute ago, deXxterlab97 said:
Mooooaaar silent
Total: $424.42
how does a web browsing rig need a dark rock 3? or a $110 psu?
But I saved OP some money and at the same time made it more silent
You are right. I could went with any air cooler and any Seasonic PSU like M12II that has been reviewed very silent to save money
a G4560 would have been more than fine with an intel stock cooler and cheap s12ii/cx450m. remember that a g4560 eats very little power, on it's own that psu isn't gonna go over 100w on load so the psu fan doesn't need to move very quickly to cool the psu, making it silent.
