My hope is to get stickied, or at least give some of us something to easily link others to when they're looking for a build guide.
SOFTWARE:
Unfortunately going into more detail regarding O/S is going to be very user-specific and each O/S could have its own entire thread (heh, forum actually). All I mean by "custom" is it's not pre-packaged.
NAS focused (Some do support virtualization, but otherwise are not type-1 hypervisors):
FreeNAS
NAS4Free
Unraid
Windows Storage Spaces
Custom: Windows + FlexRAID
Custom: Linux + ZFS
Virtualization: (You could then virtualize your NAS solution with some caveats in mind)
Linux: Everyone in the end uses KVM, so you can do it yourself or chose one that's been gussied up: Proxmox / unraid / others
Windows: Hyper-V (Included with Windows Server, also free if you download Windows Server Core Edition)
vmware: ESXi (actually runs on linux-ish, but not KVM)
Citrix: Xenserver
HARDWARE:
Nothing will include disk prices...
Used ($250+):
Pros: Cheap, rack mountable, powerful
Cons: Uses more energy than custom (120w idle), very limited options when upgrading the processor, much louder than a PC
Dell: R510, R610, R710, C2100
R510 supports up to 12 disks in 3.5 configuration
R610 supports up to 6 disks in 2.5 configuration
R710 supports up to 8 disks in 2.5, and 6 disks in 3.5 configurations
C2100 supports up to 12 disks in 3.5 configuration
Average configuration will be 24-32gb with 2x 2010-era Xeon processors (usually similar to an i7 920) and no disks. They should all be very close in price, but YMMV.
Research any raid card it may come with - ideally buy your own HBA (I'm using an IBM M1015 that I flashed to IT mode. It is a re-branded LSI card.) Some raid cards may only support 2TB and may need a firmware update.
New ($453+) Not suggested for virtualization:
Pros: Everything is shiny and new, uses slightly less energy.., can be upgraded
Cons: More expensive than used
CPU: Intel Pentium G4400 3.3GHz Dual-Core Processor $57.33
Board: ASRock H110M-HDS Micro ATX LGA1151 Motherboard $46.99
RAM: 8GB $50
Case $100
SeaSonic 360W 80+ Gold Certified ATX Power Supply $59.99
HBA card: $120
New ($683+) For virtualization:
Pros: Same as above
Cons: Same as above.
For virtualization, I would go for 32GB, it's always the first issue you hit. I'd also switch the processor out to an i3 / e3 series or better.
This gets regurgitated over and over. I forgot the HP ones so if somebody chimes in I'll add them.
https://linustechtips.com/topic/768377-nas-build-guide/
some tips/ suggestions
For the cheap build.
These will suck power about 120w idle, so look at the power bill before getting
Many old raid cards will only support drives up to 2tb
These can be very loud, heavy and big.
for the mid tier
Id go 8gb personally
beware these nics on board can suck if you want to do vlans or other fancy stuff.
For the top tier
Virt mainly wants ram, but depends on the use. Id get 32gb if your gonna be running lots of vms
Other suggestions.
For OS, Centos/ubuntu server/debian are great if you know linux well. Windows server 2016(or 2012r2 if you want) costs about 400, but works very well in a windows enviroment, and can also be used as a domain controller. Windows 10 can work as a basic nas if you like windows, but it still costs about 120 dollars and is worse in most uses compared to linux. But you have smb multichannel on windows and better AD support. For a premad nas OS freenas and openmedia vault are my current top pics.
If you want plug and play or want support look at a qnap or synology nas. They cost about 300 for a basic 4 bay and about 800 for a good 8 bay, but your getting a very low power system, plug and play support, often support for running things like vmware off it and comerical support. If you doing this for a larger buiness look at something like the dell emc storagre(but this is way out of home nas catagory and your thinking 5k+)
https://linustechtips.com/topic/768377-nas-build-guide/#findComment-9700902
@Electronics Wizardy - Added additional cons to cheapy, edited "new" one to only have 8gb (I agree, 8gb would be enough) Edited mid-tier to specifically say 32GB. However for the CPU I'd still upgrade it from a G4400. Great processor but at only 2 cores total, it gets overworked pretty quickly. The "next up" processor I'd switch to is an i3 or e3 since they're still fairly reasonably priced and will happily chug along with most home labs.
@nerdslayer1 Last I looked at Pis, you're not connecting SATA disks without a USB adapter. Not something I am going to personally recommend to anyone - better off just throwing the drives inside your personal computer and creating shares. I haven't researched nor ever tried, but I would be surprised it if could saturate a gigabit network. I believe the NIC bums a ride of the USB controller - which you'd also have your disks on... I'd get a WD mycloud before a pi.
@tt2468 I've added the R510 - however you can stick any card in any machine, and can you one way or another simply pass disks through an H700 (similar to IT mode)?
https://linustechtips.com/topic/768377-nas-build-guide/#findComment-9702703
you would be surprised also almost no power consumption.
https://linustechtips.com/topic/768377-nas-build-guide/#findComment-9702736
Unless there's a newer Pi3, they're limited to 100mbps according to the internet. Even with an adapter, you won't reach gigabit speeds thanks to USB 2.0....
https://www.cnet.com/how-to/raspberry-pi-as-cheap-nas-solution/
https://www.jeffgeerling.com/blogs/jeff-geerling/getting-gigabit-networking
https://linustechtips.com/topic/768377-nas-build-guide/#findComment-9702828
