I have my gtx 1080 since christmas but last night it started crashing every 30 min or so and it's only getting more frequent. now i can't even start any game because it crashes instantly. sometimes i even get BSOD. i tried reinstalling the driver and updated the bios, but nothing happened. i have 3 tb of programs and data so i won't be reinstalling windows that's for sure. need help asap guys, i need my pc! thanks for the help.
https://linustechtips.com/topic/768364-need-help-gtx-1080-keeps-crashing/
How is your temps? Gnerally Video cards don't cause Blue Screens... they can, but rarely. Sounds more like something else is going on. When a game crashes, what is the error it is giving.
"Black Out"
Dedicated Streaming Rig
If you've done any overclocking return the settings to default and test. When you bluescreen try to get an error code, helps with identifying the problem
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
22 hours ago, NinJake said:
Try taking out the 1080 and booting your PC. Make sure you know for a fact it's your 1080 causing crashes.
I did that and nothing crashed with integrated graphics.
Got a blue screen code, it says: CLOCK_WATCHDOG_TIMEOUT
also, i've got a new error today:
1
I think is the problem is your PSU. I have a similar problem that. Just change good brand PSU with Gold 80.
I talked to nvidia's support and they could fix my problem by enabling debugging mode in nvidia control panel.
I have a 750w gold evga psu it's an expensive and premium one it shouldn't be an issue.
same thing :) but my bsod is often appeared.
Same PSU, using very old GTX 650ti
  • 1 year later...
I think it did as it worked for me thanks to him
Although im currently using my factory OCd card at a reference card's clock speed (thats what debug mode does) it aint fun but its good to know a temporary fix.
Edited by Jalaj
  • 2 weeks later...
