The motherboard and processor won't work together. The motherboard needs to be LGA 1150. Also, where are the PSU and hard drives?
https://linustechtips.com/topic/76836-pc-noob-needs-help/#findComment-1054077
the graphics card is quite huge, it should fit in the case though. whats the psu?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/76836-pc-noob-needs-help/#findComment-1054087
Are you ninja clarkson or something?
How did you know? :ph34r:
https://linustechtips.com/topic/76836-pc-noob-needs-help/#findComment-1054098
HI, My hard drive is a Western Digital Blue 1TB and my PSU is a Corsair CX Series 600 Watt ATX/EPS Modular 80 PLUS Bronze ATX12V/EPS12V 552 Power Supply CX600M.
Regarding the Mobo and the CPU should i get another MOBO or another Cpu?
https://linustechtips.com/topic/76836-pc-noob-needs-help/#findComment-1054128
Different motherboard. Get an ASUS Z87M-PLUS.
https://linustechtips.com/topic/76836-pc-noob-needs-help/#findComment-1054140
One more point to this. If you are going to overclock in future, get K version of 4770. Otherwise don't bother getting Z87 board. H87 will have same features as Z87 but you can't change clock multiplier. It will have hyperthreading which auto-ocs 4770 to 3.9GHz.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/76836-pc-noob-needs-help/#findComment-1058508
Like everyone has explained so far either get a H87/Z87 board or a sandybridge/ivybridge CPU.
CPU: i5 4690k @4.2Ghz w/ Corsair H100i GTX | Motherboard: MSI Z97S SLI Krait Edition | RAM: Kingston HyperX Beast 16GB | GPU: Palit 1080Ti | Case: Corsair Carbide Air 540 | PSU: Seasonic G750 80+ Gold | Storage: Samsung 840 250GB, Sandisk Ultra II 960gb, WD Green 4TB, Samsung EcoGreen 2TB
CPU: i5 4670k @4 Ghz w/ Corsair H80i | Motherboard: Asus Maximus VI Impact | RAM: Corsair Vengeance Pro Series 8GB | GPU: Palit 1080Ti
Case: Bitfenix Prodigy | PSU: Corsair CXM 600W PSU 80+ Bronze | Storage: Corsair Force GS 240GB SSD
https://linustechtips.com/topic/76836-pc-noob-needs-help/#findComment-1058528
