So I was running GTA 4 on my new PC (about 5 months old now) and a small up down wave happened as an earthquake struck. It wasn't big but it was enougth for me to feel like I was moving up then down and for my monitor to wobble decently. I immediately sleeped my PC and unplugged it (faster than shutting down). I have a WD Caviar blue that had no errors whatsoever when I checked a month ago and I'm worried if that kind if upwards and downwards movement will damage it. Going to run a surface check on it sometime when the earth settles down for at least a day. Any advice on protection for the future, my case doesn't have anti vibration mounts but the HDD is screwed in tightly to the mount. My PC is on my desk.
R5 5600   Asus ROG Strix RTX2060   B550  Crucial Ballistix 16GB DDR4   Kingston A2000 1TB M.2    Kingston UV400 SSD   NZXT H510 Flow
https://linustechtips.com/topic/767608-hdds-and-earthquakes/
It should be fine. As long you don't get errors(SMART) or performance dip you shouldn't worry about it.
Magical Pineapples
https://linustechtips.com/topic/767608-hdds-and-earthquakes/#findComment-9692497
most hard disks seem to keep their warranty as long they take less than 350G of force, so I don't think an earthquake that didn't throw you to the ground will damage the hard drive
Desktop benching:
https://linustechtips.com/topic/767608-hdds-and-earthquakes/#findComment-9692518
Fyi, sleeping a computer requires power to be on.
If you unplugged it after putting it to sleep that is basically like unplugging it while it's still running.
https://linustechtips.com/topic/767608-hdds-and-earthquakes/#findComment-9692521
don't worry. I live in cali and I  get earthquakes all the time don't worry the hard drive is designed to take some abuse.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/767608-hdds-and-earthquakes/#findComment-9692567
But the HDD spins down properly either way? And parks the heads?
https://linustechtips.com/topic/767608-hdds-and-earthquakes/#findComment-9692644
Yes. As I said before, if the manufacturers give warranty if the hard drive takes less than a certain amount of forces, then they are confident that the hard drive will not fail because of that.
Desktop benching:
https://linustechtips.com/topic/767608-hdds-and-earthquakes/#findComment-9692788
When you put a computer to sleep it stores the current state in ram.
Ram is volatile memory that gets wiped when it loses power.
https://linustechtips.com/topic/767608-hdds-and-earthquakes/#findComment-9694341
