NEED FAST HELP! pc wont start proiperly after rebuild with new cables etc
Solved by Offline Research Kangaroo,
1 hour ago, astrosheen said:Strip the system back to cpu ram and motherboard(remember to move display cable). Get it to boot. Then add things back in one by one
redid everything back to default and added 1 new cable by cable until i found all cables worked then tried to move the gpu to where i need it for my casemod and then it didnt work anymore so looks like my mobo gpu slot 4 is dead or something idk why it wont register my 980ti in it , also wont register my 750 ti at all for whatever reason.
