Quietest E-ATX case?
Hello,
my two 1080Ti FE cards are really loud, so I was wondering about getting a new case.
Requirements-
-non-gamery looking, meaning I could put it in an office and no one would know.
-Glass window
-Silent-largest factor.
-Good IO
-Good build quality
-preferably E-ATX
https://linustechtips.com/topic/765213-quietest-e-atx-case/
Linus did a video about making a super quiet build. He had some guy help him, and that guy worked for some website with info on the best quiet builds. i'll try and find it.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/765213-quietest-e-atx-case/#findComment-9665780
Probably S340 Elite.
It's not the largest though.
If you want large get a caselabs case.
https://linustechtips.com/topic/765213-quietest-e-atx-case/#findComment-9665783
New case won't help much, as quiet cases have less airflow meaning higher temps = higher RPM = more noise = no difference. I would either create custom fan profile using MSI afterburner.
Fractal XL is quiet cases and is not expensive. It also can buy DIY kit by silverstone (sound dampening foam) and install on your current case.
Magical Pineapples
https://linustechtips.com/topic/765213-quietest-e-atx-case/#findComment-9665788
Just now, lilbman said:
this it?
Yup. Here's the link to the website i was talking about: http://www.silentpcreview.com/
Mouse: EVGA X17
https://linustechtips.com/topic/765213-quietest-e-atx-case/#findComment-9665790
Or you buy a 100 foot USB cable and then put the PC in the garage or something:
Mouse: EVGA X17
https://linustechtips.com/topic/765213-quietest-e-atx-case/#findComment-9665798
I can't do that, as I move the PC into my home theater sometimes to play games on my TV.  I'll keep it in mind though when I build a dedicated HTPC
https://linustechtips.com/topic/765213-quietest-e-atx-case/#findComment-9665814
You know you have run other cables such as display cable which can cost well over 100 dollars. Plus you probs have make a hole through your wall which is not wife/partner friendly. I would just try turn down fan profile, and have a headphone.
I have open back headphone and i can't hear my rig which is 100 cm from my head when at full load, usually when gaming which have sound and team voice anyways which drown out other noise.
When i rendering something, i usually watch some TV shows/YouTube/Skype and in most case only CPU is working 100% and fan profile are only running 50% and only slight burst of GPU usage which doesn't ramp fan to max.
Magical Pineapples
https://linustechtips.com/topic/765213-quietest-e-atx-case/#findComment-9667582
4 hours ago, lilbman said:
Only 100%?
Lol are you using a Raspberry Pi or something?
^ while rendering.
Magical Pineapples
https://linustechtips.com/topic/765213-quietest-e-atx-case/#findComment-9676706
