Hi guys :D
I have a small problem...
 This is what I got for an error in pcpartpicker "The CRYORIG H7 49.0 CFM CPU Cooler may require a separately available mounting adapter to fit the Asus PRIME X370-PRO ATX AM4 Motherboard "
The problem I don't know which mounting to use and where to find it.
if you can find it in like amazon.fr I will be grateful.
https://linustechtips.com/topic/765089-i-got-a-problem-with-fan-mounting/
5 minutes ago, DustHaze said:
Hi guys :D
If your issues is that it doesn't come with AM4 compatible hardware, you will have to contact the manufacturer. Generally the cheapest option since they will give you the brackets for free (generally).
but what if they didn't give me or some how I don't have this option
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
but can get it from some where else?
no, you get the cryorig am4 mounting bracket for the cryorig h7 from cryorig
desktop
HTPC
