Hello, i have problem with my hdd. It is a samsung model I haven't used it for 1.5 years as it was sitting in my drawer. The problem is that it doesn't spin. It is warming up if I leave it connected for 10-15 minutes but no signal on pc. What could be the problems?
https://linustechtips.com/topic/765037-hdd-help/
It's likely an issue that's unrelated to the HDD. Is it a laptop?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/765037-hdd-help/#findComment-9663741
Just now, PovilJ said:
Its from laptop my I am using it as external HDD atm. Because I swapped this hdd to an ssd.
When you say no signal from PC, what do you mean? Does the SSD installed in your laptop even boot into the OS? Are you trying to boot off of the HDD?
https://linustechtips.com/topic/765037-hdd-help/#findComment-9663751
This HDD was original installed in my laptop then I swapped same hdd to an ssd. And want to use this hdd as my external hard drive :)
https://linustechtips.com/topic/765037-hdd-help/#findComment-9663762
Are you able to boot into Windows from the original SSD is what I want to know. If you can, have the HDD unplugged until Windows boots up from your SSD, then plug the enclosure in.
https://linustechtips.com/topic/765037-hdd-help/#findComment-9663776
