PC Idel Temps
Go to solution Solved by genexis_x,
Replace thermal paste
At first the Problem:
my CPU´s idle temp. is grown by 10-15 °C
In December it was 18-25 °C
Now in April it is 29-35 °C
Not too long ago it wasn´t that "hot" in idle
I looked into my PC, there wasn´t too much dust, and i cleaned it but no change in the temps
My PC:
Intel Core i5 6600K (no OC -> 3.5 GHz)
CPU cooler: Be Quiet! Dark Rock 3 air cooler (180W TDP, fan at 700rpm)
GPU: MSI Nvidia Geforce GTX 970 (idle temp 32°C with changed Fan to constant 30% Fan speed in idle ~700rpm)
Case:
Fractal Design Define R5:
the 2 Included Fans in the Front(~ 400rpm)
3x Extra Fans: corsair SP 140
1 of them in the Back (~600rpm)
2 of them in the Top-Back- area (~500rpm)
Is this usual with this setup at this time, or what can I do to improve cooling performance ?
https://linustechtips.com/topic/764905-pc-idel-temps/
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/764905-pc-idel-temps/#findComment-9662146
What about your room temperature? In December you might had lower room temps.
But not 15°C difference I hope lol
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/764905-pc-idel-temps/#findComment-9662150
1 minute ago, MxKeks said:
unfortunately i dont know the temps of my room but i guess its ~23 now and in December it was ~20 I guess
Mid 30s is normal at idle if your ambient temperatures are 23.
If your ambient temperature in December was 20, then there is no way your idle temperatures were that low. In order to get room temperature on an air cooler your computer would have to be off.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/764905-pc-idel-temps/#findComment-9662163
3 minutes ago, MxKeks said:
What thermal paste would you recommend ? I used the included one from the cooler
I'm not familiar in thermal paste...only know a few like Tuniq MX-2, MX-4, Arctic Silver etc
Desktop specs:
https://linustechtips.com/topic/764905-pc-idel-temps/#findComment-9662165
Idle temps are only good for telling if your cooler is properly mounted or not. And even then you will notice it when temps hit 50C at idle. Another thing with idle is that CPU is only true idle in BIOS and right on startup. After that there's always some 5-10% load because of all background processes. Just small bump of 10% can bump temps with 5-10C.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/764905-pc-idel-temps/#findComment-9663665
