Custom Power Cables in UK?
Ykno
Where can I get custom cable in the UK that are cheaper than CableMods?
Case:- 4U Rack Mount Case | Cooler:- Antec Kuhler H600 | CPU:- Intel i5 4690K @ 4.50GHz GPU:- Zotac GeForce GTX 970 4GB AMP! Omega Core Edition @ 1449MHz | Motherboard:- MSI Z97S SLI Krait | PSU:- XFX XTR 650W Gold | RAM:- HyperX DDR3 1866MHz 4GB White (x2) Black (x2) | Storage:- Kingston V300 120GB | Storage 2:- Seagate FireCuda 1TB | Build Log |
extensions or new cables?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
Full modular cables
Its for a XFX XTR - OEM is seasonic
11 minutes ago, Ykno said:
Full modular cables
What's your budget?
I'm struggling to find cables that are not cablemods :/
4 minutes ago, Mr.Meerkat said:
What's your budget?
Ye same I'm thinking making my own is only way to go which will suck.
I only need 24 pin, 8pin Cpu, 2x 6 pin GPU and 2x sata power with 2 connectors on each
this is last item my build needs and its finished with o apart from a customer fan filter but that easy to sort.
There is the configurator on cable mods website so you can chose exactly what you're getting but I don't think its part of the EU cablemods store so you'll probably get slapped by import charges... :/
Shakmods maybe?
Icemods if you can wait a lil?
Shakmods maybe?
eBay? LOL maybe I bite the bullet and buy cablemods
2 hours ago, Mr.Meerkat said:
I keep reading thing or seeing things that looks as if corsair kits fit the seasonic/xfx PSU any idea if thats true?
If the Corsair PSUs are made by SS, it's possible that corsair had kept the same connectors and wiring soo...possibly? :D
