Hi everyone. I want to know if the P600-ATX 800W PSU worth it for my budget gaming pc? Because I have been shocked of this PSU cause it has no 4 pin cpu connector that my mobo can support. Here is the pic of the available connectors and damn I am so pissed for my 45dollars here in the Philippines. And one person quoted me that the 4 pin is only meant for a 4 pin connector and not for a 6 pin.
https://linustechtips.com/topic/763648-having-problems-with-psu-connectors/
Hey!
Luckily you don't have to get pissed over anything, you can SPLIT the 8 pin connector.
The one at the "top" of the two you're showing.
In that way it can be used as either an 8pin or 4pin.
Just leave the second 4pin hanging.
4 minutes ago, MVPernula said:
Hey!
I think its really an 8 pin power connector because of the lock. And Im afraid to force it maybe I will broke it and my warranty  is gone.
I can almost bet you my right arm that you can split it.
Google around a bit, I'm 99% sure.
3 minutes ago, MVPernula said:
I'm 100% sure now.
https://www.amazon.com/KENTEK-Supply-EPS12V-SLI-ready-PCI-Express/dp/B00596NFOI
Look at the 3rd picture advised on the left, you can see it says 4+4pin, suggesting it can be split in half.
Btw this is not a KENTEK brand this is POWERLOGIC and I am 99% sure that its an 8 pin. I will send another pic
17 minutes ago, MVPernula said:
I'm 100% sure now.
Hey again Pernula even if this was a 4 pin connector. I am not able to reach the connector itself
1 minute ago, MVPernula said:
For real? Can you give me a shot of your entire build on the inside so we can see what you're dealing with?
Well if it's too short you can buy an extension or get another PSU.
There are 8>4pin adapters.
2 minutes ago, MVPernula said:
There are adapters you can use yes.
This is an example. Considering you only need a 4pin
I splitted the 8pin already to 2x 4pin connectors. Is there another adapter that can support 4 pin to 4pin? Is there?
Yeah there is!
Shouldn't be all that hard to find. And even if you dont you can always buy an 8>4pin anyways.
Yeah there is!
Ok ok finally after all the time with you I know what to buy tomorrow. Thanks Pernula glad you helped me a lot. Please do this to everyone here that has problems they can always need a person like you ☺. Btw I want to play with you ONLINE on pc. Is there any games you play?
I enjoy these things, it's nothing really :)
I'll answer that in PM!
  • 3 years later...
Hi kuya
