I have issues on my mobile devices with VPN apps, I had to resort to using L2TP/IPsec instead as the VPN apps would close themselves. If your VPN has those options, maybe try that instead? or even better if your VPN gives you the settings to use openVPN.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/762946-vpn-connection-issues/#findComment-9640751
Rip I only have free ones. May get nordvpn
https://linustechtips.com/topic/762946-vpn-connection-issues/#findComment-9640756
Ahh I see, I don't know if it's available yet, but opera may have built in VPN in mobile browser.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/762946-vpn-connection-issues/#findComment-9640763
6 minutes ago, Jskn said:
What about tor not working?
No idea, sorry... only used tor a few times myself, too slow for my needs. If the VPN is working, shouldn't need tor anyway AFAIK, but depends on what you;re doing and what VPN you're using, whether it logs etc etc.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/762946-vpn-connection-issues/#findComment-9640805
Mods trying to not be political but the publicity of sj res 34 brought me to buy a vpn but in the mean time I used flashvpn but it stopped working.
https://linustechtips.com/topic/762946-vpn-connection-issues/#findComment-9640836
Ahh I see, I would get a good paid VPN then, and use an off-shore server... I use PIA, but there are some great ones out there, protonVPN should be active soon, but not sure of pricing for that.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/762946-vpn-connection-issues/#findComment-9640855
I was planning on tunnelbear or nordvpn
https://linustechtips.com/topic/762946-vpn-connection-issues/#findComment-9640859
Yeah, as long as they have servers in other countries that you can connect to and don't log traffic you should be fine.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/762946-vpn-connection-issues/#findComment-9640874
