Hey LTT community,
I'm a 15 year old "boy" from germany. I always had my Asus G750 Laptop for gaming. I always felt like it was enough power. But the new generation of games proved me wrong. It just feels bad to play on it now.
I always was interested in building a PC and I think now it's time. I'm planning on using it mostly for gaming (obviously) and a bit of android compiling on linux maybe.
The price shouldn't go over 2000€ and be as cheap as possible with the CPU and GPU I chose.
This is what I have so far:
Edit:
https://de.pcpartpicker.com/list/Vk4Rhq
(I couldn't find the exact Motherboard there)
MSI GeForce GTX 1070 Gaming X 8G V330-001R
https://www.amazon.de/MSI-GTX-1070-8G-V330-001R/dp/B01GRCYPE6/
Intel BX80677I77700K Quad-Core "Kaby Lake" Prozessor (Basistakt 4.20GHz, Turbotakt 4.50GHz) grau
https://www.amazon.de/Intel-BX80677I77700K-Quad-Core-Prozessor-Basistakt/dp/B01LTI1JEM/r
Be Quiet BK008 Prozessorlüfter schwarz
https://www.amazon.de/Be-Quiet-BK008-Prozessorlüfter-schwarz/dp/B01KVNCEIG/
MSI 7A78-001R Z270 Gaming M5 Mainboard (Formfaktor: ATX, Chipsatz: Intel Z270, Speicher: 4x DDR4 DIMM, maximal 64GB UDIMM) schwarz
https://www.amazon.de/MSI-7A78-001R-Gaming-Mainboard-Formfaktor/dp/B01N9NZF81/
HyperX FURY HX421C14FBK2/16 16GB Arbeitsspeicher kit (2 x 8GB) 2133MHz DDR4 Non-ECC CL14 UDIMM KIT (Skylake compatible)
https://www.amazon.de/HyperX-HX421C14FBK2-16-Arbeitsspeicher-compatible/dp/B00TY6A1LY/
Internes Crucial MX300 Solid-State-Drive 275GB M.2 2280SS (Einseitig)
https://www.amazon.de/Internes-Crucial-Solid-State-Drive-2280SS-Einseitig/dp/B01IAGSDJ0/
Seagate BarraCuda 2 TB, ST2000DM006, interne Festplatte, 8,9 cm (3,5 Zoll), 64 MB Cache, SATA 6Gb/
https://www.amazon.de/SEAGATE-Desktop-Barracuda-7200rpm-serial/dp/B01ICLGJF8/
Thermaltake View 27 Midi-Tower PC-Gehäuse schwarz
https://www.amazon.de/Thermaltake-View-Midi-Tower-PC-Gehäuse-schwarz/dp/B01KO9HFU4/
Corsair CP-9020092-EU RMX Serie RM750X ATX/EPS Voll Modular 80 PLUS Gold 750W Netzteil, EU
https://www.amazon.de/Corsair-CP-9020092-EU-RM750X-Modular-Netzteil/dp/B015Q7F4DO/
Acer Predator XB241Hbmipr 61 cm (24 Zoll) Monitor
https://www.amazon.de/Acer-XB241Hbmipr-Höhenverstellbar-Pivot-Funktion-Reaktionszeit/dp/B01AJTVBQI/
I hope It's no problem that these are german links.
Thanks in advance. (I hope my english wasn't too bad)
https://linustechtips.com/topic/762882-building-first-pc-ever/
Welcome to the forum, mate. Try using pcpartpicker.com for your PC builds. It automatically compares prices of all the different vendors out there and you can post it with one convenient link. It saves you money and the people that help you a bit of time.
WHIPLASH
CPU: Intel Core i7 6700k @4.7GHz
RAM: Corsair Vengeance RGB DDR4 2x8GB @3000MHz
MOBO: Asus ROG Maximus VIII Ranger
GPU: EVGA GTX 1080 FTW2
PSU: EVGA Supernova 650GS
CASE: Fractal Design Define S
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640151
Alright I'll do that. Thank you
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640174
7 minutes ago, Verrierr said:
Why the quotes? LGBT?
Age.
@OP
GPU looks good
i5-7600k is more than enough for just gaming.
Try to get a slightly better cooler.
Motherboard looks good.
RAM, I'd say 8GB would be enough, but if you can fit 16GB in your budget, I don't see a reason not to go with it.
SSD, don't really know how Crucial's SSD are ATM, but looks good to me
HDD looks good as well
Case. Boy, oh, boy. That case is nice, don't get me wrong, but it's a copy of a case EKWB made (IIRC), and well, I'm not a fan of copycats, but this is personal choice, so if you like, go with it. Build quality and shit, don't know anything about it. It's ThermalTake, so don't expect top notch quality.
PSU. Not sure what the market has to offer right now, but it will do.
Monitor wise, don't know shit, can't tell you if you should go with it or not.
That's all, I guess xD
*haven't made posts like these in A LOOOOOOOOONG while, man I miss this, kinda*
Oh, and this xD
Edited by JoaoPRSousa
"an obvious supporter of privacy"
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640177
4 minutes ago, ZerNico said:
No no, imo boy just a kinda weird thing to say.
3 minutes ago, Verrierr said:
Should have went with "guy". It might seem closer to "gay" but it isn't and it's not a weird thing to say.
I think he meant "boy" as in "I'm in that transitioning period from boy to man" kinda thing
Anyways, everything looks good.
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640184
17 minutes ago, JoaoPRSousa said:
Age.
@OP
GPU looks good
Oh, and this xD
I would prefer the I7 though. I always had an I7 and it definitely is helpful with Android compiling :)
I have quite a problem with finding a good not too expensive cooler. A friend of mine also said I should look for the height. It could be that it doesn't fit.
16 GB is also what I prefer. Upgraded my laptop in that regard before.
Its fine if the quality of the case isn't thaat great. It looks great and isn't too expensive so I'm good with it
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640277
Yea that's basically what I meant.
Good to hear that. It was really hard to fiddle myself into the PC stuff. Finding the parts took a while
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640286
I spent a whole year in 2014 doing research! You're not alone
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640290
I thought you only gamed, that's why I suggested the i5. But if you do other stuff that requires a beefier CPU, than sure, get the i7 :)
CPU height limit is 155mm... ¯\_(ツ)_/¯
RAM, 16gb, period. xD
Should be all gucci then. Have fun buying (less fun part... xD) and building it (most important part obviously) :D
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640297
The funnest part is me messing up the building :P
I hope I won't fail it completely as it's the first time ever doing it. But hey, I have to start somewhere
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640362
Well, I didn't fail that hard when building my first PC... YouTube videos and such are all you need in order to know how to build one IMO.
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640570
Watched many tutorials already. I also have some friends that can help me so the actual building shouldn't be that of a big problem. I'm just still not really sure about this anti static part that everyone is talking about.
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9640828
I didn't really care about the anti static thing. I just touched screwdivers n shiz every now and then just for the sake of it.
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9641010
https://de.pcpartpicker.com/list/6GzmKZ
Price breakdown by merchant: https://de.pcpartpicker.com/list/6GzmKZ/by_merchant/
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  (€358.00 @ Amazon Deutschland)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  (€115.89 @ Amazon Deutschland)
Motherboard: Asus PRIME Z270-P ATX LGA1151 Motherboard  (€126.94 @ Mindfactory)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (€134.84 @ Mindfactory)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  (€149.00 @ Amazon Deutschland)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (€79.84 @ Mindfactory)
Video Card: EVGA GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card  (€419.00 @ Amazon Deutschland)
Case: Thermaltake View 27 ATX Mid Tower Case  (€68.90 @ Amazon Deutschland)
Power Supply: Corsair 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (€132.84 @ Mindfactory)
Monitor: Asus MX27AQ 27.0" 2560x1440 60Hz Monitor  (€386.94 @ Amazon Deutschland)
Total: €1972.19
Generated by PCPartPicker 2017-04-07 00:40 CEST+0200
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9641088
13 hours ago, Abyss Gaming said:
You have 666 posts.. :0000000
SHIT I JUST RUINED IT!!!!!!
Oh well, at least this is post 6(69)
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9643333
5 hours ago, Abyss Gaming said:
I took a screenshot if you want it ;)
Just keep it for me and every now and then post it as a reply and call me the Devil lol
https://linustechtips.com/topic/762882-building-first-pc-ever/#findComment-9645533
