Hello people,
Im going to build my first pc and these are the parts.
Do you have any improvements?
Cpu: I5 7500                                                            €208.95,-
Graphics: XFX RX480 8gb                                     €265,-
Motherboard: ASRock B250M Pro4                       €88,90
Case: Cooler Master N200                                      €49,90
Ram: Corsair Vengeance LPX 2x4gb (2133MHz)    €76,90
(I just buy the cheapest kit 2133MHz)
Storage: WD Blue 1TB 7200rpm                             €54,85
PSU: Be Quiet! System Power 8 500W                    €52,90
Cpu cooler: Be Quiet! Pure Rock Slim                    €24,99
Total Price :                                                              €822,39,-
Im still thinking if I need a ssd, I thought a 120gb ssd isnt worth the price.
And a 240gb ssd costs €89,-.
I dont want to spend more than €830,-.
https://linustechtips.com/topic/762739-building-first-pc/
Kaby Lake CPU support 2400MHz RAM. Go for 1X8GB 2400MHz RAM
Aftermarket CPU cooler not necessary.
Get a better PSU if you can. The PSU you chose is not the worst but also not the best.
Get a 240/250/256GB SSD if you can afford.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638027
I would suggest waiting for the R5 line up and getting something similar to this (prices are rough, may vary for where you are and the R5 price is the American price transferred to euros so probably will be incorrect)
list is here
https://de.pcpartpicker.com/list/4tD6jc
yes it's over budget but not by much
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638036
what about the R5 line up, you could get a 6 core R5 in that budget
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638037
Waiting for benchmarks xD
Desktop specs:
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638041
oh I anit saying that the R5 line up will be the best CPUs in the world (Same with the R7 line up) but I feel like the R7 line up you will be able to say something like this
No they are not as good as intels offerings, but they are cheaper than intels offerings and their performance is better than the offerings in that price range from intel. (Mainly in multi threaded loads)
Also gaming wise, I recon over the next few years games will be released and be optimised for AMD systems as well so they performance gap will become smaller over time, cause currently they are only optimised for intel systems as there was no point optimising it for AMD
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638052
Yeah they are great CPUs for streaming+gaming and workstations.
Desktop specs:
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638070
yea, so I think that this will be a good step as it might be a bit of future proofing, for the OP to extend into other things as well.
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638071
1 minute ago, EagleMyth said:
An Amd 1500x will be around the same prize.
a 1500X is a quad (4) core the 1600 is a hex (6) core so it will probably be worth paying slightly more for the extra 2 cores and 4 threads
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638081
It's  always better to pay a bit more xD. Im trying to stay under €1000 including a monitor, pc and windows. (Maybe some extra fans)
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638089
140 euros should be able to cover the monitor and windows easily enough
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638094
Just now, EagleMyth said:
What?
I going to buy a monitor for €120, and windows isn't that cheap o.O
it depends where you get windows I believe there is places you can buy it for about $20 so about 20 euro, and I can get a windows from an old scrap PC off ebay for £10 so it's easily done within budget, so yea. don't panic to much about that
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638111
6 minutes ago, EagleMyth said:
What?
also if you are still a student you can possibly get it for free from Microsoft imagine
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9638121
4 hours ago, EagleMyth said:
Hello people,
For sure you need a SSD, makes all the difference. Specially when you start having the OS with lots of software installed.
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9639111
Hello people,
Can get rid of the Aftermarket cpu cooler, and get maybe a 500gb HDD instead of 1Tb, and the money saved, get a 240-250gb SSD.
Stock coolers will be fine for locked cpu's, you can't OC, so no real point for an aftermarket cpu cooler.
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9639361
I only get 10% discount on windows products :/ But I saw that I can buy it for $30 elsewhere.
I do have another question, should I replace the Be Quiet psu with the corsair CX500? Its €10 more
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9647732
yea get it cheaper else where. I recomend you don't buy any of that list and actually get this
https://linustechtips.com/topic/762739-building-first-pc/#findComment-9647735
