Ive heard many people find that the front panel is very restrictive, taking it off provides almost double digit cooling gains in some instances. There are some small mods that give the panel more space when its on, and also custom front panels that have cut outs in them for more direct airflow.
https://linustechtips.com/topic/762687-enthoo-evolve-atx/#findComment-9638103
Sad to hear that, did found out some thread saying that the airflow is not good . Any other suggestion mate ?
https://linustechtips.com/topic/762687-enthoo-evolve-atx/#findComment-9641699
Well not a specific thrread per say, I jsut brows the forums a lot and thats what people who owned the Evolv said.
If you're looking at something like the Evolv, I might suggest the Corsair 460X
https://linustechtips.com/topic/762687-enthoo-evolve-atx/#findComment-9643350
good idea , thinking phantek eclips as well. Thanks mate.
https://linustechtips.com/topic/762687-enthoo-evolve-atx/#findComment-9643434
