Need help deciding power supply
By
PrincipalFlash
in Power Supplies
in Power Supplies
Solved by PrincipalFlash,
4 minutes ago, STRMfrmXMN said:Not really but if you SLI it'll make a small difference to your power bill.
I think I'll go for the p2 just for the power bill down the line. The amount we're talking about is so minimal now, I can just get the better option in some sense. Thanks for the help!
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning21
play_circle_filled
Latest From ShortCircuit:
