Hi...is this ups i have intex 1000va gamma ups is it good for my system?
UPS:-http://www.intex.in/it-accessories/ups/ups-gamma-1000-3
System info:-
Cpu:-i7 6700
Cooler:-deepcool maelstrom 120t liquid cooling
Mobo:-gigabyte h110m-s2 ddr4
Memory:-kingston 16gb
Hdd:-wd blue 1tb
Gpu:-msi gtx 1080 reference card
Psu:-seasonic s12ii 520w 80+ bronze
Ups:-intex 1000va gama
Case:-cooler master N300
https://linustechtips.com/topic/762333-ups-help/
1 minute ago, Zackbare said:
No, the time is less and so is wattage, thus meaning it has shit battery.
And better don't go with Intex
Not asking about buying it, already has one.  I know nothing about this stuff but wouldn't a poor quality UPS be better than no UPS?
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/762333-ups-help/#findComment-9633033
The problem he'd face is that as soon as power goes out, the UPS will fluctuate the elec. and thus making the pc restart, defeating the purpose of it. I face that, so I connected my PC to central Inverter UPS of the house.
And, that company has really bad repo. in tech in here
-- BSOD : ( --
https://linustechtips.com/topic/762333-ups-help/#findComment-9633053
6 minutes ago, razor007 said:
-SNIP-
It's the same as getting a good PSU you want a high quality UPS, while everything looks ok on paper from what I see and it has enough wattage for your system I haven't heard of this brand before. I personally recommend units from APC, Tripplite, Eaton as a few options.
https://linustechtips.com/topic/762333-ups-help/#findComment-9633055
Frankly spend more on a great quality power supply and just use it straight on the wall, I haven't being using line filters, power stabilizers or UPs in ages, really years so far and I haven't had a single issue.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/762333-ups-help/#findComment-9633067
I'm afraid these won't be available here, and would have like insane price including import duty.
The one he's going for is like $61 in direct conversion.
-- BSOD : ( --
https://linustechtips.com/topic/762333-ups-help/#findComment-9633071
Just now, Princess Cadence said:
Frankly spend more on a great quality power supply and just use it straight on the wall, I haven't being using line filters, power stabilizers or UPs in ages, really years so far and I haven't had a single issue so far.
He suffers power outages alot, it's India my friend
-- BSOD : ( --
https://linustechtips.com/topic/762333-ups-help/#findComment-9633074
If options are limited and power is an issue then it's better than having nothing at all, just make sure the unit is capable of it's full output wattage, similar to lower quality PSU's some UPS's aren't capable of providing the full rating.
https://linustechtips.com/topic/762333-ups-help/#findComment-9633086
-- BSOD : ( --
https://linustechtips.com/topic/762333-ups-help/#findComment-9633091
The UPS is designed to eliminate or reduce that if it causes it to still shut down it could be because the unit is a Modified sinewave as some PSU's will try to protect themselves thinking it's receiving bad power. In any case he may need to source another unit that is either stepped modified or ideally a pure sinewave unit that is compatible with the hardware he has if that is the cause of the problem.
https://linustechtips.com/topic/762333-ups-help/#findComment-9633151
