MHz
Go to solution Solved by Enderman,
Yeah.
Yes, it will just run at that lower speed.
https://linustechtips.com/topic/762176-mhz/#findComment-9630829
8 minutes ago, Storm10 said:
Can 2400MHz RAM go on a 2133Mhz motherboard?
If you are referring to DDR4, yes.
2133 MHz is the JEDEC standard speed for DDR4, and anything beyond is XMP / overclocking.
All DDR4 RAM will run at 2133 MHz once you install it into your computer -- you take the extra step to make it run at 2400 MHz.
If you are referring to DDR3, then that will not be a problem either.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/762176-mhz/#findComment-9630872
Yeah.
https://linustechtips.com/topic/762176-mhz/#findComment-9630906
