Bouncing water to cool cpu
Solved by Sakkura,
It's poorly described in the article. The water condenses on the side of the vapor chamber away from the heat source, where it then bounces away because of the superhydrophobic coating. The opposite side has a superhydrophilic (water-loving) coating and a wick structure like in regular vapor chambers and heatpipes. The water evaporates there to carry away the heat from the heat source.
The idea is, more water will evaporate from hotspots. It will tend to condense on the closest area of the opposite side, and thus once the condensing liquid is bouncing back, it will be more likely to hit a hotspot.
The bouncing should also make it work well regardless of cooler orientation.
